Check your PMs Josh.
Thank you much!
The drawing MP listed the results on was a drawing I had not 'cleaned up' like I did the others, because I was not working with or using this drawing at all... I sent it as a 'control' just to see what was there before I cleaned up the drawings myself. I found, though, that even though all the drawings (including the ones I use that he cleaned up) contained over 15,000 ENTITIES, still, I had no problems whatsoever with any of the errors I had previously reported. I have been using Autocad and these drawings every day since I started this thread (including saturday and sunday) and have not encountered it since MP sent me the cleaner versions (after copying the originals to a backup folder of course) and otherwise 'cleansing' the drawings...
So what EXACTLY he took out that 'fixed' the problem, I cannot say for sure, but I know it wasn't any normal blocks or layers/styles, because one of the drawings I use, I changed all objects to the style "CASE" which is one I copied in from a purer drawing. I changed every entity to a 'clean' style and exploded all blocks (yea, so what are you gonna do about it?) and purged out all block definitions listed. The following list is from the drawing that I don't use that I did -not- do this to, as to list the contents of EVERYTHING in a drawing before the cleansing. Now I'll at least have a comparison to draw if I run into this again.
There's a lot of ADT objects though, and like MP knew all along... that's most likely the root cause.
I'm using one drawing still, that was not one that he sent me, but rather one I cleaned up like I mentioned before... and it has had no problems. So deleting all the AEC objects from ADT and purging all styles/blocks/solids/etc seems to fix the problem as well.
So there we go... the new error message "Free Store Overflow" is simply a symptom of an old problem, apparently.
202 Blocks deleted
*D132
*D133
*D134
*D135
*D136
*D154
*D155
*D156
*D157
*D158
*D159
*D160
*D161
*D162
*D163
*D164
*D165
*D166
*D167
*D168
*D169
*D170
*D171
*D172
*D173
*D174
*D175
*D176
*D177
*D178
*D179
*D180
*D184
*D202
*D203
*D204
*D205
*D206
*D207
*D208
*D209
*D210
*D211
*D212
*D213
*D221
*D222
*D223
*D224
*D225
*D226
*D227
*D228
*D229
*D230
*D231
*D233
*D234
*G198
*G199
*G200
*G201
*X54
*X55
*X56
*X57
*X58
*X59
-eqptb36
-eqptb42
-eqptp
-eqptwl
-peqlavw
-peqwct
-pewctef
-pewctes
01PARW03
01PKYX01
08PDNB01
08PDNB08
08PDRR02
08PWIC01
08PWIC02
1-8
15PTRL01
15PTRL02
220-OUTLET
3070 ext door
4' FLUORESCENT STRIP
_KTI_AT_OPEN
_KTI_AT_SWING
_out003
_rec002
A$C0917603E
A$C11917ED2
A$C1B857035
A$C21A45044
A$C2EB653CB
A$C396971FB
A$C3EF468AE
A$C51B14FA7
A$C55A6427F
A$C58576049
A$C5B2408A3
A$C5F6051C8
A$C65231485
A$C6B436680
A$C6C92407F
A$C6FC0589C
A$C70183FB0
A$C75F90667
A$C76F9085E
A-DEMO-ID
Aec_Space_Tag_P
AHEAD
AHEAD_14
arrow
ARW
break1
BREAK2
BRKLINE
CATV
CATV-EXIST
CLG-HT
COMM-PORT
COMM-PORT2
COMMPORT-FLOOR
COMMPORT-FLOOR-EXIST
diff
DISCONNECT
DOOR
DOOR-ID
DORPL01
drschedule
E-LIGHT
E-LIGHT-SWITCH
E-LIGHT24
E-SMOKEDECT
ELEC_MISC_BELL_P
ELLIPSE
EMERGENCY
EMERGENCY LIGHT-NEW
EXIT LIGHT
EXIT-LIGHT-NEW
EYEBALL-LIGHT
FAP
FLROUTLET
FLROUTLET-EXIST
GFI
HVL
I_ELEC_MISC_HORN_P
I_ELEC_MISC_JUNCTION BOX - ROUND_P
I_ELEC_MISC_JUNCTION BOX - SQUARE_P
I_ELEC_MISC_MOTOR_P
I_ELEC_MISC_STARTER - COMBO_P
I_ELEC_POWER_QUAD RECEPTACLE_P
I_ELEC_SWITCH_3 - WAY_P
I_ELEC_SWITCH_4 - WAY_P
I_ELEC_SWITCH_DIMMER_P
I_ELEC_SWITCH_SINGLE POLE_P
I_PLUMB_GRAB_36IN + PLATE_F
I_PLUMB_GRAB_36IN + PLATE_L
I_PLUMB_GRAB_36IN + PLATE_M
I_PLUMB_GRAB_36IN + PLATE_P
I_PLUMB_GRAB_42IN + PLATE_F
I_PLUMB_GRAB_42IN + PLATE_L
I_PLUMB_GRAB_42IN + PLATE_M
I_PLUMB_GRAB_42IN + PLATE_P
I_PLUMB_LAV_COUNTER 4_P
I_PLUMB_URINAL_WALL-HUNG_F
I_PLUMB_URINAL_WALL-HUNG_L
I_PLUMB_URINAL_WALL-HUNG_M
I_PLUMB_URINAL_WALL-HUNG_P
I_PLUMB_WC_BIDET_F
I_PLUMB_WC_BIDET_L
I_PLUMB_WC_BIDET_M
I_PLUMB_WC_BIDET_P
I_PLUMB_WC_FLUSH - WALL_F
I_PLUMB_WC_FLUSH - WALL_L
I_PLUMB_WC_FLUSH - WALL_M
I_PLUMB_WC_FLUSH - WALL_P
KEYNOTE
KEYPLAN
LINEAR-AC
M-SPRINKLER
M-SPRINKLER-EXIST
M-SPRINKLER-NEW
N-LIGHTS
NORTH
NORTHAR
ps-seal
QUAD-RECEPT
ra
RECESS-INCAND
RECTANG
ROOMLABEL
stair
THERM
TRUSS 4
utility-sink
WALL-INCAND
WINDOW
22 Dictionaries deleted
ACAD_IMAGE_DICT
AcadDim
AcAec
AEC_CLASSIFICATION_SYSTEM_DEFS
AEC_CLEANUP_GROUP_DEFS
AEC_DC_CONTENT
AEC_DISP_REP_CONFIGURATIONS
AEC_DISP_REP_SETS
AEC_DISP_REPS
AEC_DISPLAY_PROPS_DEFAULTS
AEC_DOOR_STYLES
AEC_ENDCAP_STYLES
AEC_LAYERKEY_STYLES
AEC_MATERIAL_DEFS
AEC_MVBLOCK_DEFS
AEC_OPENING_ENDCAP_STYLES
AEC_PROPERTY_SET_DEFS
AEC_VARS
AEC_WALL_STYLES
AEC_WALLMOD_STYLES
AEC_WINDOW_STYLES
ASE_INDEX_DICTIONARY
9 DimStyles deleted
228 Layers deleted
22 Linetypes deleted
41 RegisteredApplications deleted
