using System.IO;
using System;
namespace Purger
public class Commands
[CommandMethod("PC")]
public void PurgeCurrentDocument()
Document doc =
Application.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
Editor ed = doc.Editor;
int count =
PurgeDatabase(db);
ed.WriteMessage(
"\nPurged {0} object{1} from " +
"the current database.",
count,
count == 1 ? "" : "s"
private static int PurgeDatabase(Database db)
int idCount = 0;
Transaction tr =
db.TransactionManager.StartTransaction();
using (tr)
// Create the list of objects to "purge"
ObjectIdCollection idsToPurge =
new ObjectIdCollection();
// Add all the Registered Application names
LayerTable LT =
(LayerTable)tr.GetObject(
db.LayerTableId,
OpenMode.ForRead
foreach (ObjectId LtId in LT)
if (LtId.IsValid)
idsToPurge.Add(LtId);
// Call the Purge function to filter the list
db.Purge(idsToPurge);
Document doc =
ed.WriteMessage(
"\nLayers being purged: "
// Erase each of the objects we've been
// allowed to
foreach (ObjectId id in idsToPurge)
DBObject obj =
tr.GetObject(id, OpenMode.ForWrite);
// Let's just add to me "debug" code
// to list the registered applications
// we're erasing
LayerTableRecord LTR =
obj as LayerTableRecord;
if (LTR != null)
ed.WriteMessage(
"\"{0}\" ",
LTR.Name
obj.Erase();
// Return the number of objects erased
// (i.e. purged)
idCount = idsToPurge.Count;
tr.Commit();
return idCount;
