Currently I've got a VB COM app that I'm toying around with rewriting from the ground up using the .net api stuff as I've hit some limitations over time. I've already rewritten a few smaller ones with good success.
I've got a chance to change a few fundamental things and I'm wondering whether I should or not before I get too far into it.
One of the big components of my program is that it creates 3-4 different overall styles of Blocks based on a whole lot of different criteria, and inserts them into the drawing. Each of these blocks has a ton of attributes (most of the hidden/non-visible attributes). A typical drawing may have 5-30 of these "intelligent blocks". Alot of the reason for this program was previous to dynamic blocks, but it still does alot more than dynamic blocks do so thats not really an issue.
I'm mostly wondering at this point:
1. Currently using blocks if I create one and insert it into the drawing, then I delete the block, it's still in the database unless I do a purge. Ideally I don't want multiple references to the same block in the drawing, nor do I want a block not referenced at all. Is there another way to do that or should I have an event that watches for deletion of these blocks and purge them programatically, and also prevents multiple instances? The geometry in the blocks isn't terribly complicated. Are blocks the most efficient way to handle this?
2. Attributes vs. Xrecords? Is there any advantage to using xrecords? Are there limitations of using xrecords that I should be aware of, as I've not used them much at all, except in learning the basics of how to use them. Currently the attributes never get edited via Autocad dialogs and strictly by the application.
