Author Topic: Clip Boundaries for a Raster  (Read 40094 times)
David Hall
  • Automatic Duh Generator
Re: Clip Boundaries for a Raster
« Reply #60 on: November 15, 2007, 03:38:49 PM »
A couple of other thoughts to throw out to you.  with the two point selection method, you could just check the distance, round to the nearest whole number, and clip.  For a midpoint centered clip, you can just get them to pick a center point and distance instead of two points.
This actually is less coding, and allows the user to "center" the clipping box based on a selected point.  Much easier and cleaner if you ask me
David Hall
« Reply #61 on: November 15, 2007, 03:40:10 PM »
Bob is on the right track of what I was thinking.  Bob, how do you do the default thing???  In LISP I know you use <> to define it, but I never learned how in VBA
You use error handling with VBA I throw the <crap> into my prompt so it looks familiar to Johnny Caduserguy but it's handle with the error trapping.
So you trap NULL?
David Hall
« Reply #62 on: November 15, 2007, 03:41:06 PM »
do you use a form of initget? and set bits to allow null entry, and then trap for the null?
ML
« Reply #63 on: November 15, 2007, 03:51:10 PM »
It is actually a very clever idea but it still all boils down to "what" is the need
In my application; it needs to be fitted into a 5 x 5 box on a title block; so yes, they could have said I prefer to have this area centered but that is ok; then can still pick a very small or specific area on the raster and the 5 x 5 will get made with that area is basically centered.
I think this offers a lot of flexibility as they have the window option.
I am curious to try that dynamic boundary code though
David Hall
« Reply #64 on: November 15, 2007, 04:08:15 PM »
ill write something up for you
ML
« Reply #65 on: November 15, 2007, 04:09:51 PM »
OK Guys
Here is the total accumulation of what we had done; hopefully others can benefit from it.
Bob, your last method is the last one in the code; the rest are commented out
It is really cool!
The user can type in the size and it is created.
The only thing I noticed is that it did not regenerate on bigger sizes; not sure why.
Sub InstRast()
Dim RastImg As AcadRasterImage
Dim Imgpth As String
Dim Imgname As String
Dim InsertPnt(0 To 2) As Double, scalefactor As Double, RotAngle As Double
Imgpth = "Path"
Imgname = "filename"
InsertPnt(0) = 0#: InsertPnt(1) = 0#: InsertPnt(2) = 0#
scalefactor = 1
RotAngle = 0
On Error GoTo Errorhandler
Set RastImg = ThisDrawing.PaperSpace.AddRaster(Imgpth & Imgname, InsertPnt, scalefactor, RotAngle)
RastImg.Name = Imgname
RastImg.Name = Left(Imgname, Len(Imgname) - 4)
RastImg.scalefactor = 12
'Move Points
 Dim Point1(0 To 2) As Double
 Dim Point2(0 To 2) As Double
 Point1(0) = 8: Point1(1) = 0: Point1(2) = 0
 Point2(0) = 0: Point2(1) = 0: Point2(2) = 0
'Move Raster
 RastImg.Move Point1, Point2
Errorhandler:
   If Err.Description = "File access error" Then
    If MsgBox("Can not find image file") Then
     Exit Sub
    End If
   End If
Dim llpnt As Variant 'lower left point
Dim urpnt As Variant 'upper right point
Dim mdpnt(0 To 2) As Double
Dim clipPoints(0 To 9) As Double
With ThisDrawing.Utility
 llpnt = .GetPoint(, vbCrLf & "Select Lower Left Point: ")
 urpnt = .GetPoint(, vbCrLf & "Select Upper Right Point: ")
End With
mdpnt(0) = (llpnt(0) + urpnt(0)) / 2 'Midpoint (X) = (The far left picked point + the far right picked point) / 2
mdpnt(1) = (llpnt(1) + urpnt(1)) / 2 'Midpoint (Y) = (The far bottom picked point + the far top picked point) / 2
mdpnt(2) = 0
'FINITE
'Create a 5 x 5 clip boundary
'  clipPoints(0) = 0: clipPoints(1) = 0
'  clipPoints(2) = 0: clipPoints(3) = 5
'  clipPoints(4) = 5: clipPoints(5) = 5
'  clipPoints(6) = 5: clipPoints(7) = 0
'  clipPoints(8) = 0: clipPoints(9) = 0
'Clip boundary = 2.5 from the mdpnt of the raster's picked points to the boundary coords.
'  clipPoints(0) = mdpnt(0) - 2.5: clipPoints(1) = mdpnt(1) - 2.5
'  clipPoints(2) = mdpnt(0) - 2.5: clipPoints(3) = mdpnt(1) + 2.5
'  clipPoints(4) = mdpnt(0) + 2.5: clipPoints(5) = mdpnt(1) + 2.5
'  clipPoints(6) = mdpnt(0) + 2.5: clipPoints(7) = mdpnt(1) - 2.5
'  clipPoints(8) = mdpnt(0) - 2.5: clipPoints(9) = mdpnt(1) + -2.5
'DYNAMIC
'Clip boundary = picked points (llpnt + urpnt)
'  clipPoints(0) = llpnt(0): clipPoints(1) = llpnt(1)
'  clipPoints(2) = llpnt(0): clipPoints(3) = urpnt(1)
'  clipPoints(4) = urpnt(0): clipPoints(5) = urpnt(1)
'  clipPoints(6) = urpnt(0): clipPoints(7) = llpnt(1)
'  clipPoints(8) = llpnt(0): clipPoints(9) = llpnt(1)
'Clip boundary =  user defined size
  Dim Bndsize As Integer
  Bndsize = ThisDrawing.Utility.GetReal("What size boundary would you like?: ")
  clipPoints(0) = mdpnt(0) - Bndsize / 2: clipPoints(1) = mdpnt(1) - Bndsize / 2
  clipPoints(2) = mdpnt(0) - Bndsize / 2: clipPoints(3) = mdpnt(1) + Bndsize / 2
  clipPoints(4) = mdpnt(0) + Bndsize / 2: clipPoints(5) = mdpnt(1) + Bndsize / 2
  clipPoints(6) = mdpnt(0) + Bndsize / 2: clipPoints(7) = mdpnt(1) - Bndsize / 2
  clipPoints(8) = mdpnt(0) - Bndsize / 2: clipPoints(9) = mdpnt(1) + -Bndsize / 2
'Clip the image
 RastImg.ClipBoundary clipPoints
'Enable the display of the clip
 RastImg.ClippingEnabled = True
 ThisDrawing.Regen acActiveViewport
David Hall
« Reply #66 on: November 15, 2007, 04:17:28 PM »
guess you beat me to it, Ill just chec thru yours
David Hall
« Reply #67 on: November 15, 2007, 04:19:50 PM »
the only thing I see, which has no effect on the running of the code b/c order of operation is correct is
clipPoints(0) = mdpnt(0) - Bndsize / 2While it is correct, I would personally use () to make it clearer to someone reading it that Bndsize/2 comes before MP-
David Hall
« Reply #68 on: November 15, 2007, 04:20:15 PM »
clipPoints(0) = mdpnt(0) - (Bndsize / 2)
David Hall
« Reply #69 on: November 15, 2007, 04:21:54 PM »
what if you place a breakpoint, does it stop there?
Bob Wahr
« Reply #70 on: November 15, 2007, 04:28:40 PM »
You might try thowing a RastImg.Update in there, not sure if it will help.
ML
« Reply #71 on: November 15, 2007, 04:29:16 PM »
Haven't tried that but I certainly can
Here you go sir
clipPoints(0) = mdpnt(0) - (Bndsize / 2): clipPoints(1) = mdpnt(1) - (Bndsize / 2)
  clipPoints(2) = mdpnt(0) - (Bndsize / 2): clipPoints(3) = mdpnt(1) + (Bndsize / 2)
  clipPoints(4) = mdpnt(0) + (Bndsize / 2): clipPoints(5) = mdpnt(1) + (Bndsize / 2)
  clipPoints(6) = mdpnt(0) + (Bndsize / 2): clipPoints(7) = mdpnt(1) - (Bndsize / 2)
  clipPoints(8) = mdpnt(0) - (Bndsize / 2): clipPoints(9) = mdpnt(1) + -(Bndsize / 2)
ML
« Reply #72 on: November 15, 2007, 05:01:14 PM »
Bob
RastImg.Update
Did not help
Bob Wahr
« Reply #73 on: November 15, 2007, 05:03:15 PM »
You're gonna make me open autocad, aren't you?
ML
« Reply #74 on: November 15, 2007, 06:29:21 PM »
LOL
No, I'm sure not
I think we have worked you enough today  LOL
Tomorrow is a new day!  :-)
