Author Topic: 08, VBA, and Vista  (Read 6597 times)
David Hall
  • Automatic Duh Generator
08, VBA, and Vista
« on: November 10, 2007, 03:36:44 PM »
Has anyone gotten VBA and 08 to play nicely on Vista?  I brought some of my code from work home, and kept getting catastrophic failures. (Thats what the msgbox says, yet Autocad doesn't crash.)  I'm beginning to think Vista is a really bad thing for Autocad at this point
They say money can't buy happiness, but it can buy Bacon and that's a close second
Re: 08, VBA, and Vista
« Reply #1 on: November 10, 2007, 03:40:07 PM »
Try running AutoCAD as an administrator. Right click shortcut "Run as administrator".
Trying to run Visual BASIC 6 otherwise was a gong show, especially when trying to compile dlls (kept getting a friendly and illuminating 0x80004005 error).
You can set shortcuts to always run as said state (on shortcurt by shortcut basis), which makes it a little easier.
« Last Edit: November 10, 2007, 03:48:01 PM by MP »
David Hall
« Reply #2 on: November 10, 2007, 03:46:19 PM »
I did the rigft click thing, and that didn't help.
David Hall
« Reply #3 on: November 10, 2007, 03:46:55 PM »
and the sub is very basic
Public Sub VPLock()
      On Error GoTo Err_Control
      Dim vp As AcadPViewport
      Dim gpCode(0) As Integer
      Dim dataValue(0) As Variant
      Dim objSelSet As AcadSelectionSet
      gpCode(0) = 0
      dataValue(0) = "VIEWPORT"
      Set objSelSet = ThisDrawing.SelectionSets.Add("VPL")
      objSelSet.Select acSelectionSetAll, , , gpCode, dataValue
      For Each vp In objSelSet
            If vp.DisplayLocked = True Then
                  vp.DisplayLocked = False
            End If
      Next
Exit_Here:
      Exit Sub
Err_Control:
      Select Case Err.Number
      Case "-2145320851"
            ThisDrawing.SelectionSets.Item("VPL").Delete
            Err.Clear
            Resume
      Case Else
            MsgBox Err.Number & Err.Description
            Err.Clear
            Resume Exit_Here
      End Select
« Reply #4 on: November 10, 2007, 03:49:21 PM »
YEOW!
Sorry, without a clue (more than normally that is).
David Hall
« Reply #5 on: November 10, 2007, 03:51:27 PM »
Funny thing is, in the local window, 80% of the entries say "No Database" like VBA suddenly lost the connection to the dwg.  Even if Im in the Thisdrawing module.
« Reply #6 on: November 10, 2007, 03:58:45 PM »
I ran your code on machine Cmdr and no errors (Vista Ultimate + AutoCAD '08).
(And it did unlock locked viewports).
David Hall
« Reply #7 on: November 10, 2007, 04:30:33 PM »
I have Vista Home Premium i think
edit : Confirmed
David Hall
« Reply #8 on: November 10, 2007, 04:51:39 PM »
MP, How?  I haven't seen this anywhere, but I will admit I haven't looked to hard.  I hate Vista, but I know I will have to learn it soon enough
David Hall
« Reply #9 on: November 10, 2007, 04:54:57 PM »
Just found it. we will see if that fixes my code
« Reply #10 on: November 10, 2007, 04:55:53 PM »
<fingers crossed>
David Hall
« Reply #11 on: November 10, 2007, 05:09:10 PM »
did'nt fix it
DinØsaur
  • Certified Bovine Scat Distributor...I lay it on THICK
  • But I don't WANT a Day Job
« Reply #12 on: November 10, 2007, 07:23:00 PM »
IT at work is testing Vista Ultimate 64 wit Civil 3D 2008 (crammed FULL of VBA) and is not having any similar issues.
Stephen R. Sherrill,
The DinØsaur
Civil 3D Specialist Emeritus
YAY ME !!!  I made it out alive !
joseguia
« Reply #13 on: November 11, 2007, 02:11:40 AM »
Vista/Cad 64Bit or 32Bit?
I have had issues with Vista 64bit and 2008 (64bit), but none with Vista 32 Bit and 2008(32bit).
David Hall
« Reply #14 on: November 11, 2007, 10:01:59 AM »
32 both items.  I wonder if its b/c of the Home Edition?
