I'll admit, I haven't given this a lot of thought - but before I do, I thought I would run it by you experts and maybe save some time....
Given an LWPOLYLINE and a list of points that fall on this polyline, I need to be able to break the original polyline into smaller segments defined by the points in the polyline. The points may be anywhere on the original polyline, not just at the vertices. The purpose of the breaks is to be able to assign different linetypes to each section.
If you were doing this manually, you could just literally break the polyline at each point. But I need to do this in VBA and there may be hundreds of points along this polyline.
See attached image also.
TIA
