Author Topic: List of object properties to an array?  (Read 21919 times)
mkweaver
« on: November 08, 2007, 02:33:06 PM »
I would like to get a list of all the properties for an object into an array.  Is there any way to do this with VBA?
Specifically, I want to get all of the properties for a layer along with the values so I can store them or copy them to another drawing.  I don't want to specify the properties because I want the code to accept new properties as they are added to the object model.
All suggestions welcome,
Mike Weaver
Bob Wahr
Re: List of object properties to an array?
« Reply #1 on: November 08, 2007, 02:43:47 PM »
I don't think it's possible.  I would really love to be proven wrong on this, just because it will be cool to see though.
mkweaver
« Reply #2 on: November 08, 2007, 02:57:16 PM »
MSDN has an article http://msdn.microsoft.com/msdnmag/issues/1200/TypeLib/default.aspx that explains how to do it using tlbinf32.dll, but I was hoping there was something built into vba.
Mike
« Reply #3 on: November 08, 2007, 05:11:11 PM »
Can be done with Lisp.  Look at the 'atoms-family' function.
mkweaver
« Reply #4 on: November 08, 2007, 07:03:03 PM »
Tim,
The only way I can see to possibly get a list of object properties with Atoms-Family is to check each member of Atoms-Family against my object to see if it is a property of that object using vlax-property-available-p.  Is this what you had in mind, or is there another way I'm missing?
Mike Weaver
« Reply #5 on: November 08, 2007, 07:31:26 PM »
Tim,
Mike Weaver
That is the way I was thinking, and how it was shown to me my MP (from here).  I don't know of any other way Mike.
Glenn R
« Reply #6 on: November 08, 2007, 08:51:52 PM »
Clone it using an AxDbDocument and ThisDrawing.CopyObjects from memory.
SomeCallMeDave
« Reply #7 on: November 08, 2007, 09:40:09 PM »
Mike
Using info from above link, this code (as ugly and kludgy as it may be) will return a collection filled with properties of a desired Autocad entity
Function BestClassInfo(ByVal Object As Object) As TypeInfo
  Set BestClassInfo = TLI.ClassInfoFromObject(Object)
  On Error GoTo NotAvailable
  With BestClassInfo.Parent
    With TLI.TypeLibInfoFromRegistry _
         (.GUID, .MajorVersion, .MinorVersion, .LCID)
      Set BestClassInfo = .Me.TypeInfos.IndexedItem(BestClassInfo.TypeInfoNumber)
    End With
  End With
  Exit Function
NotAvailable:
  Err.Clear
End Function
Function ImplementedInterfaces( _
  ByVal ccInfo As CoClassInfo, _
  Libs As Collection, _
  Optional ByVal fIncludeDefault As Boolean = True) As SearchResults
Dim SR As SearchResults
Dim IFace As InterfaceInfo
Dim TLInf As TypeLibInfo
Dim TLInfLast As TypeLibInfo
Dim strKey As String
Dim TypeInfos(0) As Integer
Dim tinfoDefault As IUnknown
Dim fLookupLib As Boolean
  Set Libs = New Collection
  If Not fIncludeDefault Then
    Set tinfoDefault = ccInfo.DefaultInterface.ITypeInfo
  End If
  On Error GoTo Error
  For Each IFace In ccInfo.Interfaces
    If 0 = (IFace.AttributeMask And _
            (IMPLTYPEFLAG_FSOURCE Or IMPLTYPEFLAG_FRESTRICTED)) Then
        If tinfoDefault Is IFace.ITypeInfo Then
          'Turn off default check once we find it
          fIncludeDefault = True
          GoTo DoNext
        End If
      End If
      Set TLInf = IFace.Parent
      TypeInfos(0) = IFace.TypeInfoNumber
      fLookupLib = True
      If TLInfLast Is Nothing Then
      ElseIf TLInf.IsSameLibrary(TLInfLast) Then
        'TLInfLast is simply an optimization.
        'Checking IsSameLibrary is faster than
        'doing a collection lookup.
        fLookupLib = False
        'Use the TypeLibInfo object from the
        'collection so that it has the LibNum set
        Set TLInf = TLInfLast
      End If
If fLookupLib Then
        strKey = CStr(ObjPtr(TLInf.ITypeLib))
        On Error Resume Next
        Set TLInf = Libs(strKey)
        If Err Then
          'New library
          TLInf.LibNum = Libs.Count + 1
          Libs.Add TLInf, strKey
          Set TLInfLast = TLInf
        End If
        On Error GoTo Error
      End If
      'Call AddTypes, appending to the previous collection
      Set ImplementedInterfaces = _
       TLInf.AddTypes(TypeInfos, ImplementedInterfaces, , False)
    End If
DoNext:
  Next
  Exit Function
Error:
  Resume DoNext
End Function
Public Function ExtractProperties(pEntTypeName As String) As Collection
'Calling Code
Dim SI As SearchItem
Dim Libs As Collection
Dim SRMembers As SearchResults
Dim ccInfo As CoClassInfo
Dim xCoInfo1 As CoClassInfo
Dim xCoInfo2 As CoClassInfo
Dim xTLInfo3 As TypeLibInfo
Dim myCoClasses As CoClasses
Dim strEntType As String
Dim oMyObj As Object
Dim i As Integer
Dim myTypeInfo As TypeInfo
Dim PropList() As String
Dim myInterfaceInfo As InterfaceInfo
Dim PropCollection As Collection
strEntType = "AcadCircle"
Set ccInfo = BestClassInfo(ThisDrawing)
Set SR = ImplementedInterfaces(ccInfo, Libs)
If Not SR Is Nothing Then
  SR.Sort
  For Each SI In SR
    'Do a set first to avoid late bound calls
    'against TLI objects
    Set TLInf = Libs(SI.LibNum)
    Set SRMembers = TLInf.GetMembers(SI.SearchData)
    'Process members
  Next
End If
Set myCoClasses = Libs.Item(1).CoClasses
For i = 1 To myCoClasses.Count
  Set xCoInfo1 = myCoClasses(i)
  If xCoInfo1.Name = pEntTypeName Then
     Set xCoInfo2 = xCoInfo1
     Set myTypeInfo = TLInf.GetTypeInfo(xCoInfo2.TypeInfoNumber)
  End If
  Set xCoInfo1 = Nothing
Next
Set myInterfaceInfo = xCoInfo2.Interfaces(1)
ReDim PropList(1 To myInterfaceInfo.Members.Count)
Set PropCollection = New Collection
For i = 1 To myInterfaceInfo.Members.Count
    PropList(i) = myInterfaceInfo.Members(i).Name
    If myInterfaceInfo.Members(i).InvokeKind = INVOKE_PROPERTYGET Then
       PropCollection.Add myInterfaceInfo.Members(i).Name
    End If
Next i
Set ExtractProperties = PropCollection
End Function
' ********this is the callable code  ************
Public Sub TestExtract()
  Dim colProperties As Collection
  Set colProperties = New Collection
  Set colProperties = ExtractProperties("AcadCircle")  ' put your desire entity here
Most of the code comes from the Help file for Type Lib Information Library.
Your VBA project must include a reference to TypeLineInformation (tlbinf32.dll)
Have fun  :)
The result are in the attached image
mkweaver
« Reply #8 on: November 08, 2007, 10:01:40 PM »
Tim,
Mike Weaver
With Layer set to a layer object, I get the following:
(setq temp (vl-remove-if-not (function (lambda(var)
(vlax-property-available-p layer var))) (atoms-family 0)))
(LAYERON)
Not quite what I was expecting
SomeCallMeDave
« Reply #9 on: November 08, 2007, 10:14:59 PM »
OK, forget all that stuff in my previous post.
It gets a WHOLE lot easier.
A reference to TypeLineInformation (tlbinf32.dll) is still needed.
Public Sub testGetProps()
    Dim cData As Collection
    Set cData = dkb_GetProperties(ThisDrawing.ModelSpace(0)) 'select your object however suits you best
Public Function dkb_GetProperties(pObject As Acad0bject) As Collection
    Dim iInterFaceInfo As InterfaceInfo
    Dim cClassInfo As TypeInfo
    Dim i As Integer
    Set iInterFaceInfo = InterfaceInfoFromObject(pObject)
    For i = 1 To iInterFaceInfo.Members.Count
        If iInterFaceInfo.Members(i).InvokeKind = INVOKE_PROPERTYGET Then
            colProperties.Add iInterFaceInfo.Members(i).Name
        End If
    Next i
    Set dkb_GetProperties = colProperties
End Function
« Last Edit: November 08, 2007, 10:16:47 PM by SomeCallMeDave »
SomeCallMeDave
« Reply #10 on: November 08, 2007, 10:18:20 PM »
Here is the results for a layer
Set cData = dkb_GetProperties(ThisDrawing.Layers(0))
mkweaver
« Reply #11 on: November 08, 2007, 10:42:21 PM »
Very good, Dave!
« Reply #12 on: November 08, 2007, 10:44:47 PM »
<applause.wav>
(Sorry for the brevity, long day, I'm bagged).
Bob Wahr
« Reply #13 on: November 09, 2007, 01:17:26 AM »
Not the first time and it won't be the last but my hat is off to you Dave.
SomeCallMeDave
« Reply #14 on: November 09, 2007, 07:19:39 AM »
Thanks guys, but all I really did was explore a help file and play with the Locals window in VBA.
tlbinf32.dll is definitely worth investigating.  If I find any more goodies, I will post them.
I'm thinking this might be a good way to find some hidden functions/properties.
