Author Topic: AddVertexAt  (Read 8527 times)
Bryco
AddVertexAt
« on: November 08, 2007, 09:08:26 AM »
If you don't know the amount of verticies required when you create the pline and you want to keep adding verticies or if you want to add a verticie to an existing pline, I seem to get an elock problem.
oPline.UpgradeOpen(); doesn't seem to help.
When adding a new entity, the blocktable and the BlockTableRecord need OpenMode.ForWrite, is this necessary for modifying an entity?
MickD
Re: AddVertexAt
« Reply #1 on: November 08, 2007, 03:40:15 PM »
yes, with OpenForRead you can 'study' the object and get it's properties but if you want to change it you need to tell the db that you're taking control of the object which means no one else can use it while you have it to avoid multiple user issues.
- John Carmack
- J.R.R. Tolkien
MickD
Re: AddVertexAt
« Reply #2 on: November 08, 2007, 03:42:37 PM »
To elaborate a bit further, a symbol table record is just like a normal db record, you need to create it first (which means it's automatically open for writing at that point), add your data to the necessary fields and close it. If you want to edit it you need to get the record, open it for editing and so on.
hth.
- John Carmack
- J.R.R. Tolkien
Bryco
Re: AddVertexAt
« Reply #3 on: November 08, 2007, 10:53:05 PM »
Thanks Mick, I'll try that on the weekend
sinc
Re: AddVertexAt
« Reply #4 on: November 09, 2007, 11:02:41 AM »
If all you want to do is edit an existing polyline, you do not need to do anything with Block Tables or Block Table Records.
However, you DO need to open the polyline itself for write.  You can do this by opening it for write, or by opening it for read and using UpgradeOpen().  And as with all interactions with the drawing database, you must use a transaction for this.
The following two code snippets are identical.  The oId is an object ID, such as one returned by Editor.GetSelection().  This code simply insert a point to the beginning of the selected polyline, so that it now starts at (0,0).
using (Transaction tr = HostApplicationServices.WorkingDatabase.TransactionManager.StartTransaction())
    Polyline p = tr.GetObject(oId, OpenMode.ForWrite, false) as Polyline;
    if (p != null)
        p.AddVertexAt(0, new Point2d(), 0, 0, 0);
    tr.Commit();
    Polyline p = tr.GetObject(oId, OpenMode.ForRead, false) as Polyline;
    if (p != null)
        p.UpgradeOpen();
    tr.Commit();
Bryco
Re: AddVertexAt
« Reply #5 on: November 09, 2007, 12:49:41 PM »
Thanks Sinc, that'll get me there.
It's Alive!
  • Retired
  • AKA Daniel
Re: AddVertexAt
« Reply #6 on: November 09, 2007, 03:04:19 PM »
Just to keep your weekend busy   :laugh:
using System;
using AcDb = Autodesk.AutoCAD.DatabaseServices;
[assembly: CommandClass(typeof(AddVertex.Commands))]
namespace AddVertex
  public class Commands
    public Commands(){}
    [CommandMethod("test")]
    static public void test()
      Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
      try
        PromptEntityOptions selopts = new PromptEntityOptions("Select a Polyline");
        selopts.AllowNone = false;
        PromptEntityResult result = ed.GetEntity(selopts);
        if (result.Status == PromptStatus.OK)
          ObjectId id = result.ObjectId;
          Database Db = HostApplicationServices.WorkingDatabase;
          AcDb.TransactionManager Tm = Db.TransactionManager;
          using (Transaction tr = Tm.StartTransaction())
              Entity ent = (Entity)Tm.GetObject(id, OpenMode.ForRead);
              if (ent is Polyline)
                PromptIntegerResult intres = ed.GetInteger("\nEnter an int now!");
                PromptPointResult ptres = ed.GetPoint("Go and get a point3d boy!");
                Point2d ptToInsert = new Point2d(ptres.Value.X, ptres.Value.Y);
                Polyline pl = (Polyline)ent;
                if (intres.Value <= pl.NumberOfVertices)
                  pl.UpgradeOpen();
                  List<Point2d> ptList = new List<Point2d>();
                  for (int j = 0; j < pl.NumberOfVertices; j++)
                    ptList.Add(pl.GetPoint2dAt(j));
                  pl.AddVertexAt(0, ptToInsert, 0, 0, 0);
                  ptList.Insert(intres.Value, ptToInsert);
                  for (int k = 0; k < pl.NumberOfVertices; k++)
                    pl.SetPointAt(k, ptList[k]);
                else
                  ed.WriteMessage("\nint is less than NumberOfVertices");
              else
                ed.WriteMessage("\nnot a polyline");
            tr.Commit();
      catch (System.Exception ex)
        ed.WriteMessage(ex.Message);
Bryco
Re: AddVertexAt
« Reply #7 on: November 09, 2007, 06:32:47 PM »
That's going to be handy Daniel, as I also want to draw a poly using a jig.
Kean Walmsley has an example of this but no arcs and his use of drawvector works great until you zoom or pan.
I thought I would have to draw a pline, do an arc or line jig, then draw a new pline, delete the old, continue.
Now it seems I can adjust the pline as I go.
Although the Undo part of the command (not looking forward to that) may be easier if I just hide the old plines and not delete them,
or (Head hurts thinking about it)
Glenn R
Re: AddVertexAt
« Reply #8 on: November 09, 2007, 07:25:25 PM »
Actually, no, you don't.
It's Alive!
  • Retired
  • AKA Daniel
Re: AddVertexAt
« Reply #9 on: November 10, 2007, 08:31:47 AM »
In some instances you may need to convert your LwPolyline to a Polyline2d. If you run into this have a look at the methods Polyline.ConvertFrom() and Polyline.ConvertTo(). I personally haven’t used them, but according to the docs you can transfer the handle, persistent reactors, XData .etc. so the end user doesn’t know you’re replacing entities.
Dan
« Last Edit: November 10, 2007, 10:50:28 AM by Daniel »
sinc
Re: AddVertexAt
« Reply #10 on: November 10, 2007, 09:00:40 AM »
Gotta love these incredibly informative posts that say nothing but "you're wrong"...    :roll:
It's Alive!
  • Retired
  • AKA Daniel
Re: AddVertexAt
« Reply #11 on: November 10, 2007, 09:25:38 AM »
Actually, no, you don't.  :lol:
sinc
Re: AddVertexAt
« Reply #12 on: November 10, 2007, 09:29:30 AM »
 :-D
Re: AddVertexAt
« Reply #13 on: November 10, 2007, 10:13:03 AM »
'must' is the key word ..
You can use .Open() and .Close() for everything, but I wouldn't like to. :lol:
Glenn R
Re: AddVertexAt
« Reply #14 on: November 10, 2007, 10:46:19 PM »
I didn't say you were wrong - you assumed I did. I was merely pointing out that transactions aren't the only way to do things. Also, it wasn't meant to be informative, as there is a very recent thread in this board that goes into speed of drawing 3d solids if I remember correctly and in there it discusses the open/close paradigm compared with transactions. A search for 'transaction speed' and the first result is the thread I refer to.
Spot on Kerry.
