Kerry, I got it to work with a few tips, I digged from Autodesk discussion forum. Thanks to javenkat!
I'm posting the code, so that it may be of help to others who is just into C#.
using Autodesk.AutoCAD.Colors;
using System;
using System.Collections.Specialized;
using System.Windows.Forms;
namespace XU2
public class XU : IExtensionApplication
public static Matrix3d ucs;
public static ObjectId curLayer;
private Autodesk.AutoCAD.ApplicationServices.DocumentCollection docs = null;
public void Initialize()
DocumentCollection dm = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager;
dm.DocumentLockModeChanged += new DocumentLockModeChangedEventHandler(Change);
//Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
//doc.CommandEnded += new CommandEventHandler(doc_CommandEnded);
docs = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager;
foreach (Document doc in docs)
Attach(doc);
docs.DocumentCreated += new Autodesk.AutoCAD.ApplicationServices.DocumentCollectionEventHandler(r1);
docs.DocumentToBeDestroyed += new Autodesk.AutoCAD.ApplicationServices.DocumentCollectionEventHandler(r2);
public void Terminate()
docs.DocumentCreated -= new Autodesk.AutoCAD.ApplicationServices.DocumentCollectionEventHandler(r1);
docs.DocumentToBeDestroyed -= new Autodesk.AutoCAD.ApplicationServices.DocumentCollectionEventHandler(r2);
private void Change(object sender, DocumentLockModeChangedEventArgs e)
if (e.GlobalCommandName == "XATTACH")
ModifyLayers();
CreateLayer();
ucs = UCS2WCS();
private static ObjectId CreateLayer()
ObjectId layerId = ObjectId.Null;//the return value for this function
Editor ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor;
curLayer = db.Clayer;
using (Transaction trans = db.TransactionManager.StartTransaction())
//Get the layer table first...
LayerTable lt = (LayerTable)trans.GetObject(db.LayerTableId, OpenMode.ForRead);
//Check if 0-XREF exists;;;
if (lt.Has("0-XREF"))
layerId = lt["0-XREF"];
db.Clayer = layerId;
else
//if not, create the layer here.
LayerTableRecord ltr = new LayerTableRecord();
ltr.Name = "0-XREF";
ltr.Color = Color.FromColorIndex(ColorMethod.ByAci, 1);
ltr.IsFrozen = false;
ltr.IsLocked = false;
ltr.IsOff = false;
//upgrade the open from read to write
lt.UpgradeOpen();
layerId = lt.Add(ltr);
trans.AddNewlyCreatedDBObject(ltr, true);
trans.Commit();
return layerId;
public void ModifyLayers()
try
LayerTable lt = (LayerTable)tr.GetObject(db.LayerTableId, OpenMode.ForRead);
foreach (ObjectId objId in lt)
LayerTableRecord ltr = (LayerTableRecord)tr.GetObject(objId, OpenMode.ForWrite);
if (ltr.Name == "0" || ltr.Name == "Defpoints")
if (ltr.IsLocked) { ltr.IsLocked = false; }
if (ltr.IsFrozen) { ltr.IsFrozen = false; }
if (ltr.IsOff) { ltr.IsOff = false; }
catch (System.Exception ex)
MessageBox.Show(ex.Message);
public static Matrix3d UCS2WCS()
Matrix3d original = ed.CurrentUserCoordinateSystem;
ed.CurrentUserCoordinateSystem = Matrix3d.Identity;
return original;
void doc_CommandEnded(object sender, CommandEventArgs e)
try
ed.WriteMessage("\n The command is " + e.GlobalCommandName);
ed.CurrentUserCoordinateSystem = ucs;
ed.WriteMessage("\n" + ucs);
db.Clayer = curLayer;
void doc_CommandCancelled(object sender, CommandEventArgs e)
try
if (e.GlobalCommandName == "XATTACH" )
void r1(object sender, Autodesk.AutoCAD.ApplicationServices.DocumentCollectionEventArgs e)
Attach(e.Document);
void r2(object sender, Autodesk.AutoCAD.ApplicationServices.DocumentCollectionEventArgs e)
Detach(e.Document);
private void Attach(Document doc)
doc.CommandEnded +=new CommandEventHandler(doc_CommandEnded);
doc.CommandCancelled +=new CommandEventHandler(doc_CommandCancelled);
private void Detach(Document doc)
doc.CommandEnded -= new CommandEventHandler(doc_CommandEnded);
doc.CommandCancelled -= new CommandEventHandler(doc_CommandCancelled);
But if I run XATTACH through the XREF dialog box, the CommandEnded and CommandCancelled Event is not fired. Hence the layer and ucs doesn't go back to the original setting.
