Author Topic: (Challange) Insert at position  (Read 11837 times)
« on: July 30, 2004, 12:11:18 PM »
Alright you guys, you know the rules! Get to it!
I want a tool to insert an item into a list at a specific postion (zero based).
(<tool name here>
    [item] [position])
    Example:
    given a list: (1 2 4 5 6 7)
    (insert@ '(1 2 4 5 6 7) 3 2)
    -> (1 2 3 4 5 6 7)
    And ....GO!
    « Reply #1 on: July 30, 2004, 12:14:51 PM »
    OBTW, I found one of Reni's posts that has a util like this a few days ago and i thought it was a good idea for a challenge.
    ...And since im using Crappystation today i will post that procedure a bit later and maybe get to writing one of my own at lunch.
    Re: (Challange) Insert at position
    « Reply #2 on: July 30, 2004, 12:48:10 PM »
    Quote from: Se7en
    (<tool name here>
      [item] [position])
      Example:
      -> (1 2 3 4 5 6 7)
      And ....GO!
      Certainly not optimized, but here's my quick stab at it:
      (defun ListInsert ( lst item position / i index1 index2 )
              (   (< position 1) (cons item lst))
              (   (< (length lst) position) (append lst (list item)))
              (   (setq i -1)
                  (append
                      (reverse
                          (mapcar 'cdr
                              (member
                                  (assoc (1- position)
                                      (setq index2
                                          (reverse
                                              (setq index1
                                                  (mapcar
                                                     '(lambda (x) (cons (setq i (1+ i)) x))
                                                      lst
                                  index2
                      (list item)
                      (mapcar 'cdr (member (assoc position index1) index1))
      (listinsert '(1 2 4 5 6 7) 3 2) ==> (1 2 3 4 5 6 7)
      Cheers,
      M.
      « Reply #3 on: July 30, 2004, 01:19:44 PM »
      (defun insert@ (lst itm pos / nlst idx)
        (setq nlst '()
              idx -1)
        (while (< (setq idx (1+ idx)) (length lst))
          (if (= idx pos)
            (setq nlst (cons (nth idx lst) (cons itm nlst)))
            (setq nlst (cons (nth idx lst) nlst))
        (reverse nlst)
      « Reply #4 on: July 30, 2004, 01:44:27 PM »
      Quote from: CAB
        (setq nlst '()
              idx -1)
          (if (= idx pos)
        (reverse nlst)
      Hi CAB,
      It is tempting to go that route, because it's less code, but you would be surprised at the difference in performance. Try this:
      (setq lst '(0 0))
      (repeat 15 (setq lst (append lst lst)))
      Now bench the execution time of
      (ListInsert lst 1 1)
      versus
      (Insert@ lst 1 1)
      Actually, you don't even neeed to bench it, the difference is dramatic enough you don't need execution times to see the difference (which is the order of about 500). Obviously on short lists the performance difference is negligable, but I frequently deal with huge lists, thus the performance concern.
      Havin' fun,
      M
      « Reply #5 on: July 30, 2004, 01:56:15 PM »
      w00t! discussion!
      CAB, that is the same thing i was thinking.
      MP, good point.
      As i promised, here is Reni U.'s procedure.
      ;;; Insert atom in list at pos n
      (defun insert (lst x n)
          ((zerop n) (cons x lst))
          (T (cons (car lst) (insert (cdr lst) x (1- n))))))
      Now taking into concideration MP's big list point and the fact that this lil procedure uses a recursive method, should there be a concern?
      « Reply #6 on: July 30, 2004, 01:59:47 PM »
      WOW, 500!
      I had no idea there was that much difference.
      « Reply #7 on: July 30, 2004, 02:21:12 PM »
      OK, How about this one :shock:
      (defun insert@ (lst itm pos / ptr)
        (setq ptr (nth pos lst))
        (append (reverse(cdr(member ptr (reverse lst)))) (list itm) (member ptr lst))
      « Reply #8 on: July 30, 2004, 03:32:34 PM »
      I think it looks perty CAB. (Does that count?)
      What no one else has a say 'cept MP CAB and Reni?!
      « Reply #9 on: July 30, 2004, 03:44:48 PM »
      Here are my timer test.
        (startTimer)
        (repeat 1000
         (Insert '(1 2 4 5 6 7) 3 2)
        (endTimer "instest")
      New insert@
      Timed instest: 0.009978
      Old insert@
      Timed instest: 0.029974
      M's ListInsert Routine
      Timed instest: 0.059988
      Old insert@ again
      Timed instest: 0.030014
      Timed instest: 0.019996
      New insert@ again
      Timed instest: 0.020036
      Timed instest: 0.010018
      M's ListInsert Routine again
      Timed instest: 0.070006
      Timed instest: 0.060028
      Timed instest: 0.060993
      Insert by Reni U.
      « Reply #10 on: July 30, 2004, 05:17:18 PM »
      I think you will find that your new function only works as long as every single item in the existing list is unique.
      The performance of Reine's function progressivley degrades the closer the replacement position is to the far end of the list (when the list is of significant length).
      Also, Reine's is limitied by the stack (because it recurses). Try Reine's function on the list I created above and insert at the second last position.
      *Kaboom*.
      « Reply #11 on: July 30, 2004, 05:22:32 PM »
      MP, Thats kinda my point. What makes Mapcar free form that restraint since it too is recursive  by nature. ...well for that matter Lisp is recursive isnt it!?
      « Reply #12 on: July 30, 2004, 05:42:16 PM »
      Quote from: MP
      SHOOT, BACK TO THE DRAWING BOARD. :)
      « Reply #13 on: July 30, 2004, 07:56:26 PM »
      Quote from: Se7en
      MP, That's kinda my point. What makes Mapcar free form that restraint since it too is recursive  by nature. ...well for that matter Lisp is recursive isn't it!?
      Is mapcar recursive? I don't know that it is or isn't, but I'm leaning towards not.  If it were recursive it would be subject to stack failures, and I've never seen a mapcar call produce a stack failure. That doesn't mean it can't happen, just that I've never seen it happen in 15 years of LISP programming.
      LISP comfortably supports recursive calls (the first language to support recursion if I'm not mistaken), but I wouldn't say "it's recursive". LIST based for sure, and some LISP processing is recursive, but in my way of thinking a blanket "is recursive" statement doesn't fit. However, this is another unqualified opinion.
      Having said that, I'm just a hack -- some real bit head with fully functioning grey matter will have to step up to the plate because I don't know the internal workings of the LISP engine.
      Cheers. :)
      SMadsen
      « Reply #14 on: July 30, 2004, 08:15:30 PM »
      I'd do it much like CAB's first INSERT@ function
      (defun insert@ (lst item n / a nlst)
        (setq a 0)
        (while lst
          (and (= a n) (setq nlst (cons item nlst)))
          (setq nlst (cons (car lst) nlst)
                lst  (cdr lst)
                a    (1+ a))
        (reverse nlst)
      (setq alst '(A B C D E F G))
      (insert@ alst '(X Y Z) 3)
      (A B C (X Y Z) D E F G)
