Author Topic: hatch reactor  (Read 12884 times)
ELOQUINTET
hatch reactor
« Reply #15 on: November 06, 2003, 01:04:31 PM »
i can't seem to figure it out :cry:
when i was asking you about this line:
;; If command is for creating hatches, then put the currently
;; active layer into the reactors data field and set layer "HATCH"
i was asking you where is the reactors data field. i always type in h for hatch so i would like the hatch layer  to react to h input. the dim reactor works fine (except for the color problem) i just want to try to add hatch to that reactor. i put that reactor at the end of my acad2000 lisp file and included it in the startup suite and it worked good, just want hatch to react too without having to load or unload anything. i'm just trying to tell you exactly what i'm looking for so you don't possibly waste time reinventing the wheel so to speak. thanks
dan
