Author Topic: DevTV: Introductory recordings on Autodesk APIs  (Read 19787 times)
Re: DevTV: Introductory recordings on Autodesk APIs
« Reply #15 on: November 14, 2007, 11:55:55 PM »
Yes, It can be done ..
just a bit tricky when dealing with new concepts ..
and I don't have the time at the moment.
the real waste is that EVERYONE who wants to play with C# has to translate the code,
and that may proove a little difficult for newb's ...
Michael's use of the "P" word covers it nicely
.. professionally written C# (sample)....
Nathan Taylor
« Reply #16 on: November 15, 2007, 01:23:17 AM »
Lucky I ignored eveyones advice on C#.
« Reply #17 on: November 15, 2007, 05:24:49 AM »
Anyone .. ?
I've wittled them down from 74 to 8 to 3
Some of the fixups may be less than perfect .. I'm a little brain dead :-)
Error   4   'fullEntPath' is a 'variable' but is used like a 'method'
 ... fixed
added:
and the 2 solutions ZIP FILES REMOVED :-
« Last Edit: November 15, 2007, 09:48:51 AM by Kerry Brown »
« Reply #18 on: November 15, 2007, 05:50:33 AM »
Any VB'rs know why these warnings would be suppressed ... ( I bite my tongue)
Warning   9   '42016' is not a valid warning number   DevTvIntro
It's Alive!
  • Retired
  • AKA Daniel
« Reply #19 on: November 15, 2007, 09:10:41 AM »
Kerry, please look at this one.. don't have much time to play as I have family visiting this week
« Reply #20 on: November 15, 2007, 09:28:26 AM »
Thanks Dan .. That seems to do the trick .... I couldn't see the trees for the forest !
Haven't tested all .. but it compiles, netloads and runs 'helloworld' :-)
I'm off to bed !
ta man !
« Last Edit: November 15, 2007, 09:36:41 AM by Kerry Brown »
Glenn R
« Reply #21 on: November 15, 2007, 08:20:06 PM »
I'm sorry I missed this Kerry. I didn't realise you were posting questions about the source code.
Are you still having trouble? If so, let me know and when I get back from breakfast (I'm in Singapore at the moment) I'll have a go at rewriting it for you and anybody else.
Cheers,
Glenn.
« Reply #22 on: November 15, 2007, 08:32:49 PM »
Hi Glenn,
sorry I missed the send -off !
The code Dan posted compiles, netloads and runs the simple stuff.
however,
After the Palette and addDBEvents Commands are run the TreeView is not visible on the pallete and subsequent drawing additions crash Acad.
I'm running in 3 directions at once , so if you have a moment between drinks and pestering hosties ...
Glenn R
« Reply #23 on: November 15, 2007, 08:44:25 PM »
Neat trick ;)
I'll see what I can do...the view is quite exceptional...<wanders off>
« Reply #24 on: November 15, 2007, 08:47:35 PM »
Kerry's a triathlete?
« Reply #25 on: November 15, 2007, 08:58:08 PM »
>>  triathlete
 :lmao:
It's Alive!
  • Retired
  • AKA Daniel
« Reply #26 on: November 15, 2007, 09:43:46 PM »
Try this one, it seems the controls didn’t get translated correctly
« Reply #27 on: November 15, 2007, 10:47:42 PM »
quick Test ... seems to hold together Dan.
I'll have a look tonight. Thanks heaps!
« Reply #28 on: November 15, 2007, 10:59:03 PM »
I've just had one of 'those' thoughts ...
I wonder if doing the translation from VB to C# with Lutz Roeder's Reflector would be more efficient and accurate than using SharpDevelop ??
[addToListOfThingsToTest]
LE
« Reply #29 on: November 15, 2007, 11:55:34 PM »
Do not know what of the demos you guys are using.... I download the first one on the list and opened on visual studio 2005, removed the debug to a2008, did the compile and open it using lutz reflector and getting something like:
[CommandMethod("addAnEnt")]
public void AddAnEnt()
    Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
    PromptKeywordOptions getWhichEntityOptions = new PromptKeywordOptions("Which entity do you want to create? [Circle/Block] : ", "Circle Block");
    PromptResult getWhichEntityResult = ed.GetKeywords(getWhichEntityOptions);
    if (getWhichEntityResult.Status == PromptStatus.OK)
        switch (getWhichEntityResult.StringResult)
            case "Circle":
                PromptPointOptions getPointOptions = new PromptPointOptions("Pick Center Point : ");
                PromptPointResult getPointResult = ed.GetPoint(getPointOptions);
                if (getPointResult.Status == PromptStatus.OK)
                    PromptDistanceOptions getRadiusOptions = new PromptDistanceOptions("Pick Radius : ");
                    getRadiusOptions.BasePoint = getPointResult.Value;
                    getRadiusOptions.UseBasePoint = true;
                    PromptDoubleResult getRadiusResult = ed.GetDistance(getRadiusOptions);
                    if (getRadiusResult.Status == PromptStatus.OK)
                        Database dwg = ed.Document.Database;
                        Transaction trans = dwg.TransactionManager.StartTransaction();
                        try
                            Circle circle = new Circle(getPointResult.Value, Vector3d.ZAxis, getRadiusResult.Value);
                            ((BlockTableRecord) trans.GetObject(dwg.CurrentSpaceId, OpenMode.ForWrite)).AppendEntity(circle);
                            trans.AddNewlyCreatedDBObject(circle, true);
                            trans.Commit();
                        catch (Exception exception1)
                            ProjectData.SetProjectError(exception1);
                            Exception ex = exception1;
                            ed.WriteMessage("problem due to " + ex.Message);
                            ProjectData.ClearProjectError();
                        finally
                            trans.Dispose();
                break;
            case "Block":
                PromptStringOptions blockNameOptions = new PromptStringOptions("Enter name of the Block to create : ");
                blockNameOptions.AllowSpaces = false;
                PromptResult blockNameResult = ed.GetString(blockNameOptions);
                if (blockNameResult.Status == PromptStatus.OK)
                    try
                        BlockTableRecord newBlockDef = new BlockTableRecord();
                        newBlockDef.Name = blockNameResult.StringResult;
                        BlockTable blockTable = (BlockTable) trans.GetObject(dwg.BlockTableId, OpenMode.ForRead);
                        if (!blockTable.Has(blockNameResult.StringResult))
                            blockTable.UpgradeOpen();
                            blockTable.Add(newBlockDef);
                            trans.AddNewlyCreatedDBObject(newBlockDef, true);
                        Point3d VB$t_struct$S0 = new Point3d(0.0, 0.0, 0.0);
                        Circle circle1 = new Circle(VB$t_struct$S0, Vector3d.ZAxis, 10.0);
                        VB$t_struct$S0 = new Point3d(20.0, 10.0, 0.0);
                        Circle circle2 = new Circle(VB$t_struct$S0, Vector3d.ZAxis, 10.0);
                        VB$t_struct$S0 = new Point3d(40.0, 20.0, 0.0);
                        Circle circle3 = new Circle(VB$t_struct$S0, Vector3d.ZAxis, 10.0);
                        VB$t_struct$S0 = new Point3d(60.0, 30.0, 0.0);
                        Circle circle4 = new Circle(VB$t_struct$S0, Vector3d.ZAxis, 10.0);
                        VB$t_struct$S0 = new Point3d(80.0, 40.0, 0.0);
                        Circle circle5 = new Circle(VB$t_struct$S0, Vector3d.ZAxis, 10.0);
                        newBlockDef.AppendEntity(circle1);
                        newBlockDef.AppendEntity(circle2);
                        newBlockDef.AppendEntity(circle3);
                        newBlockDef.AppendEntity(circle4);
                        newBlockDef.AppendEntity(circle5);
                        trans.AddNewlyCreatedDBObject(circle1, true);
                        trans.AddNewlyCreatedDBObject(circle2, true);
                        trans.AddNewlyCreatedDBObject(circle3, true);
                        trans.AddNewlyCreatedDBObject(circle4, true);
                        trans.AddNewlyCreatedDBObject(circle5, true);
                        PromptPointOptions blockRefPointOptions = new PromptPointOptions("Pick insertion point of Block : ");
                        PromptPointResult blockRefPointResult = ed.GetPoint(blockRefPointOptions);
                        if (blockRefPointResult.Status != PromptStatus.OK)
                            trans.Dispose();
                        else
                            BlockReference blockRef = new BlockReference(blockRefPointResult.Value, newBlockDef.ObjectId);
                            ((BlockTableRecord) trans.GetObject(dwg.CurrentSpaceId, OpenMode.ForWrite)).AppendEntity(blockRef);
                            trans.AddNewlyCreatedDBObject(blockRef, true);
                            trans.Commit();
                    catch (Exception exception2)
                        ProjectData.SetProjectError(exception2);
                        Exception ex = exception2;
                        ed.WriteMessage("a problem occured because " + ex.Message);
                    finally
                        trans.Dispose();
                break;
[CommandMethod("addData")]
public void addData()
    PromptEntityResult getEntityResult = ed.GetEntity("Pick an entity to add an Extension Dictionary to : ");
    if (getEntityResult.Status == PromptStatus.OK)
        Transaction trans = ed.Document.Database.TransactionManager.StartTransaction();
        try
            Entity ent = (Entity) trans.GetObject(getEntityResult.ObjectId, OpenMode.ForRead);
            if (ent.ExtensionDictionary.IsNull)
                ent.UpgradeOpen();
                ent.CreateExtensionDictionary();
            DBDictionary extensionDict = (DBDictionary) trans.GetObject(ent.ExtensionDictionary, OpenMode.ForRead);
            try
                ObjectId entryId = extensionDict.GetAt("MyData");
                ed.WriteMessage("\nThis entity already has data...");
                Xrecord myXrecord = (Xrecord) trans.GetObject(entryId, OpenMode.ForRead);
                foreach (TypedValue value in myXrecord.Data)
                    ed.WriteMessage("\n" + value.TypeCode.ToString() + " . " + value.Value.ToString());
                extensionDict.UpgradeOpen();
                Xrecord myXrecord = new Xrecord();
                TypedValue[] VB$t_array$S0 = new TypedValue[5];
                TypedValue VB$t_struct$S1 = new TypedValue(70, 1);
                VB$t_array$S0[0] = VB$t_struct$S1;
                TypedValue VB$t_struct$S2 = new TypedValue(1, "MyStockData");
                VB$t_array$S0[1] = VB$t_struct$S2;
                TypedValue VB$t_struct$S3 = new TypedValue(40, 51.9);
                VB$t_array$S0[2] = VB$t_struct$S3;
                TypedValue VB$t_struct$S4 = new TypedValue(40, 100.0);
                VB$t_array$S0[3] = VB$t_struct$S4;
                TypedValue VB$t_struct$S5 = new TypedValue(40, 320.6);
                VB$t_array$S0[4] = VB$t_struct$S5;
                ResultBuffer data = new ResultBuffer(VB$t_array$S0);
                myXrecord.Data = data;
                extensionDict.SetAt("MyData", myXrecord);
                trans.AddNewlyCreatedDBObject(myXrecord, true);
                if (this.myPalette != null)
                    try
                        foreach (TreeNode node in this.myPalette.TreeView1.Nodes)
                            if (Operators.ConditionalCompareObjectEqual(node.Tag, ent.ObjectId.ToString(), false))
                                TreeNode childNode = node.Nodes.Add("Extension Dictionary");
                                    childNode.Nodes.Add(value.ToString());
                                goto Label_0302;
                    finally
                        IEnumerator VB$t_ref$L1;
                        if (VB$t_ref$L1 is IDisposable)
                            (VB$t_ref$L1 as IDisposable).Dispose();
            Label_0302:
            trans.Commit();
        finally
            trans.Dispose();
[CommandMethod("addDataToNOD")]
public void addDataToNOD()
    try
        DBDictionary nod = (DBDictionary) trans.GetObject(ed.Document.Database.NamedObjectsDictionaryId, OpenMode.ForRead);
        try
            ObjectId entryId = nod.GetAt("MyData");
            nod.UpgradeOpen();
            TypedValue VB$t_struct$S0 = new TypedValue(70, 1);
            VB$t_array$S0[0] = VB$t_struct$S0;
            TypedValue VB$t_struct$S1 = new TypedValue(1, "MyCompanyDefaultSettings");
            VB$t_array$S0[1] = VB$t_struct$S1;
            TypedValue VB$t_struct$S2 = new TypedValue(40, 51.9);
            VB$t_array$S0[2] = VB$t_struct$S2;
            TypedValue VB$t_struct$S3 = new TypedValue(40, 100.0);
            VB$t_array$S0[3] = VB$t_struct$S3;
            TypedValue VB$t_struct$S4 = new TypedValue(40, 320.6);
            VB$t_array$S0[4] = VB$t_struct$S4;
            nod.SetAt("MyData", myXrecord);
        trans.Commit();
        ed.WriteMessage("a problem occurred because " + ex.Message);
    finally
        trans.Dispose();
