Author Topic: ObjectDBX Xref for block  (Read 19712 times)
OcCad
Re: ObjectDBX Xref for block
« Reply #15 on: November 01, 2007, 02:18:11 PM »
I'm still getting the same return. When I try to see where it gets messed up it seems its as if its here:
    (setq dwgName InsName)
    ;create an ObjectDBX Document
    (setq dbxDoc (vla-GetInterfaceObject (vlax-get-acad-object)
         ObjectDBX.AxDbDocument.16))
      (vlax-invoke dbxDoc "Open" dwgName)
    ;get the desired block
"dwgName" will return a value however "dbxDoc" returns nil as does "dbxBlocks."
VovKa
  • Ukraine
« Reply #16 on: November 01, 2007, 02:47:43 PM »
is dbx server registered?
version of Acad?
« Reply #17 on: November 01, 2007, 02:48:29 PM »
See if this will get what you are looking for.  It's what I use courtesy of Jeff M.
(setq dbxApp
 (if (< (atoi (setq oVer (substr (getvar "acadver") 1 2))) 16)
  (vla-GetInterfaceObject (vlax-get-acad-object) "ObjectDBX.AxDbDocument")
  (vla-GetInterfaceObject (vlax-get-acad-object) (strcat "ObjectDBX.AxDbDocument." oVer))
What version of Cad are you on?
OcCad
« Reply #18 on: November 01, 2007, 02:49:40 PM »
AC 2008
VovKa
  • Ukraine
« Reply #19 on: November 01, 2007, 03:11:07 PM »
if still getting an error, then register dbx server
((lambda (v)
   (if (not
(vl-registry-read
   (strcat "HKEY_CLASSES_ROOT\\ObjectDBX.AxDbDocument." v "\\CLSID")
     (startapp "regsvr32.exe"
       (strcat "/s \"" (findfile (strcat "AxDb" v ".dll")) "\"")
  (substr (getvar "ACADVER") 1 2)
OcCad
« Reply #20 on: November 01, 2007, 03:14:02 PM »
still...
"; error: ActiveX Server returned an error: Parameter not optional" :-(
« Reply #21 on: November 01, 2007, 03:20:35 PM »
If you're using 2008 object dbx should already be registered:
(   (lambda ( version )
        (vl-registry-read
            (strcat "HKEY_CLASSES_ROOT\\ObjectDBX.AxDbDocument"
                (if (eq 15 version)
                    "\\CLSID"
                    (strcat "." (itoa version) "\\CLSID")
    (atoi (getvar "acadver"))
=> "{49998808-648A-4A9C-A7A5-B1672775D9AB}"
« Last Edit: November 01, 2007, 03:22:12 PM by MP »
OcCad
« Reply #22 on: November 01, 2007, 03:24:01 PM »
May you know what parameter is registering as not optional?
« Reply #23 on: November 01, 2007, 03:29:53 PM »
Copy/paste the last code I posted to the command line, and post back what it returns.
VovKa
  • Ukraine
« Reply #24 on: November 01, 2007, 03:30:24 PM »
put it this way
(strcat "ObjectDBX.AxDbDocument." (substr (getvar "acadver") 1 2))
what value doe's (findfile dwgName) return?
OcCad
« Reply #25 on: November 01, 2007, 03:36:46 PM »
TW: #<VLA-OBJECT IAxDbDocument 11150390>
(defun c:xrs ()
  (command "-layer" "make" "S-ANNO-XREF" "color" "7" "" "ltype" "continuous" "" "s" "" "")
 (INITDIA)
  (command "xattach" pause)
    (setq EntName  (entlast))
    (setq EntData  (entget EntName))
    (setq InsName  (cdr (assoc 2 EntData)))
    (setq InsScale (cdr (assoc 41 EntData)))
    (setq InsPoint (cdr (assoc 10 EntData)))
     ;Register DBX Server
     (setq dbxApp
    (setq dbxBlocks (vla-get-blocks dbxDoc))
    (setq dbxBlock (vla-item dbxBlocks "Detail Bdr"))
    (setq dbxEname (vlax-vla-object->ename dbxBlock))
      (setq dbxEntData (entget dbxEname))
        (setq dbxBlockInsert (cdr (assoc 331 dbxEntData)))
        (setq dbxScale (cdr (assoc 41 (entget dbxBlockInsert))))
    (vlax-release-object dbxDoc)
      (setq dbxDoc nil)
   (command "scale" EntName "" InsPoint (/ 1 dbxScale))
;;after the insert
  (setq EL (entget (entlast)))
  (prompt (strcat "\nInserted " (cdr (assoc 2 EL)) " at scale " (rtos (* 12 (cdr (assoc 41 EL)))) " = 1' "))
« Reply #26 on: November 01, 2007, 03:43:00 PM »
In the code replace all the calls to 'dbxDoc' to 'dbxApp' and then remove (or comment out) the portion of the code that assigns 'dbxDoc' as you don't need it.  The way I show (or VovKa shows) is a better way to get it.
OcCad
« Reply #27 on: November 01, 2007, 03:48:11 PM »
Thats closer. Now no nils up until "dbxblocks"
« Reply #28 on: November 01, 2007, 03:51:22 PM »
Did you change the call to the new variable?  The easiest way is to do a find/replace on the whole file.  That is if you are using Notepad, or some other program that works like that.  How are you editing your file?
VovKa
  • Ukraine
« Reply #29 on: November 01, 2007, 03:54:46 PM »
one more error:
insted of
write
(setq InsName (cdr (assoc 1 (tblsearch "BLOCK"(cdr (assoc 2 EntData))))))
