Author Topic: Separate layouts to individual dwg files.  (Read 26751 times)
CADaver
« on: October 31, 2007, 10:27:45 AM »
A client asked, I told him I'd check.   I searched here but no luck.  Is there a tool out there somewhere that will take a multi-layout tabbed file and make individual files with one layout tab each??
(Might as well explode dimensions while you're at it, sheesh!)
Slim©
  • The Dude Abides...
Re: Separate layouts to individual dwg files.
« Reply #1 on: October 31, 2007, 10:38:40 AM »
I believe that ToolPac from DotSoft has that ability.
I drink beer and I know things....
deegeecees
« Reply #2 on: October 31, 2007, 10:41:50 AM »
Sounds easy enough. Pseudo code:
Get # of layouts to list
Create a copy of dwg file for each layout (length of list)
Delete all but 1 of the layouts for each dwg, iterating through the list
I think Alan can be of more help on this.
LE
« Reply #3 on: October 31, 2007, 10:42:23 AM »
Randy;
Have a look in the lisp section of www.jtbworld.com
Here is a direct link:
http://www.jtbworld.com/lisp/layoutstodwgs.htm
There is one lisp there, that it does that.
« Last Edit: October 31, 2007, 10:49:24 AM by LE »
« Reply #4 on: October 31, 2007, 11:29:43 AM »
Here is my rewrite of Jimmy's routine. I've had better luck with this finishing the job plus it ignores tabs with nothing on them.
(defun c:layoutstodwgs (/ ct doc exprt fda lays msg pre)
  (setq fda   (getvar 'filedia)
pre   (getstring "\n Enter filename prefix: ")
exprt (getvar 'expert)
ct    (getvar 'ctab)
doc   (vla-get-activedocument (vlax-get-acad-object))
lays  (vla-get-layouts doc)
msg   ""
  (setvar 'filedia 0)
  (setvar 'expert 5)
  (setvar 'tilemode 1)
  (command "_ucs" "_w")
  (foreach l (layoutlist)
    (setvar 'ctab l)
    (if (> (sslength (ssget "_x" (list (cons 410 (getvar 'ctab))))) 1)
      (progn (vla-endundomark doc)
     (vla-startundomark doc)
     (vlax-for x lays
       (and (/= (vla-get-name x) (getvar 'ctab)) (vl-catch-all-apply 'vla-delete (list x)))
     (command "_-wblock" (strcat (getvar 'dwgprefix) pre l) "*")
     (setq msg (strcat (getvar 'dwgprefix) pre l ".dwg created.\n" msg))
     (command "_u")
      (setq msg (strcat "Tab " l " has nothing on it and skipped.\n" msg))
  (setvar 'filedia fda)
  (setvar 'expert exprt)
  (setvar 'ctab ct)
  (princ msg)
« Last Edit: January 14, 2014, 08:52:24 AM by ronjonp »
« Reply #5 on: October 31, 2007, 11:58:47 AM »
I tried one or two of these routines in the past and the problem was that they exported the objects
that were in paper space but left behind the objects visible in the viewports. So that was not good
for my use. I never pursed it as my need for such a routine was a one time thing.
Maybe Ron's routine will do that?  8-)
« Reply #6 on: October 31, 2007, 12:03:16 PM »
From my tests it grabbed all that is needed.
« Reply #7 on: October 31, 2007, 12:09:11 PM »
Here is my entry.  With some slight modifications it could be used with ObjectDBX.
(defun c:Tabs->Drawings (/ ActDoc MsObjList PsObjList dbxApp oVer FirstPass)
(setq ActDoc (vla-get-ActiveDocument (vlax-get-Acad-Object)))
(vlax-for obj (vla-get-ModelSpace ActDoc)
(setq MsObjList (cons obj MsObjList))
(vlax-for lo (vla-get-Layouts ActDoc)
(if (/= (vla-get-Name lo) "Model")
(setq FirstPass T)
(vlax-for obj (vla-get-Block lo)
(if (not FirstPass)
(setq PsObjList (cons obj PsObjList))
(setq FirstPass nil)
(setq dbxApp
(if (< (atoi (setq oVer (substr (getvar "acadver") 1 2))) 16)
(vla-GetInterfaceObject (vlax-get-acad-object) "ObjectDBX.AxDbDocument")
(vla-GetInterfaceObject (vlax-get-acad-object) (strcat "ObjectDBX.AxDbDocument." oVer))
(vlax-invoke ActDoc 'CopyObjects MsObjList (vla-get-ModelSpace dbxApp))
(vlax-invoke ActDoc 'CopyObjects PsObjList (vla-get-PaperSpace dbxApp))
(vla-SaveAs dbxApp (strcat (vla-get-Path ActDoc) "\\" (vla-get-Name lo)))
(vlax-release-object dbxApp)
(setq dbxApp nil)
(setq PsObjList nil)
CADaver
« Reply #8 on: November 01, 2007, 09:29:17 AM »
Thanks guys appreciate the help.  I'll pass the info off to the client if thats okay with everyone who offered help?
« Reply #9 on: November 01, 2007, 09:51:39 AM »
Not a problem here....except the logic behind it. :-D
« Reply #10 on: November 01, 2007, 11:02:31 AM »
I have no problem.  Mine will overwrite though without warning, FYI.
CADaver
« Reply #11 on: November 01, 2007, 11:04:09 AM »
I think I'll add code to explode all the dimensions while we're at it.
CADaver
« Reply #12 on: November 01, 2007, 11:05:08 AM »
Even better.  I haven't tested any of them, and I will indicate such to the client.  Thanks for the help.
Bob Wahr
« Reply #13 on: November 01, 2007, 11:13:51 AM »
Some other functionality you might want to consider
explode all blocks
for each thingy in the DWuG
get layer of thingy
apply color setting of layer to thingy
apply linetype setting of layer to thingy
change layer to 0
« Reply #14 on: November 01, 2007, 11:49:27 AM »
We could also move all XREF's to arbitrary base points and change all the scale factors to random numbers.  :-D
