Author Topic: C# 3.0 automatic properties  (Read 2352 times)
It's Alive!
  • Retired
  • AKA Daniel
« on: October 30, 2007, 02:35:39 PM »
Here is one of the new features of C# 3.0 & VS2008 (.NET 2.0).
As you can see in the class UserProfile, I did not need to make the private fields. The compiler will generate the fields for me.
The Class UserProfile:
public class UserProfile
    public string FName { get; set; }
    public string LName { get; set; }
Reflected
    // Fields
    [CompilerGenerated]
    private string <FName>k__BackingField;
    [CompilerGenerated]
    private string <LName>k__BackingField;
    // Properties
    public string FName
        [CompilerGenerated]
        get
            return this.<FName>k__BackingField;
        [CompilerGenerated]
        set
            this.<FName>k__BackingField = value;
    public string LName
        [CompilerGenerated]
        get
            return this.<LName>k__BackingField;
        [CompilerGenerated]
        set
            this.<LName>k__BackingField = value;
It seems like a cool feature for the small quick classes, I don’t think I would use it for complex classes though.
One thing I don’t really care for is that, it doesn’t play well with structs and it is supposed to rid the need for
parameterized constructors. Anyone play with this feature yet? Thoughts?
namespace Testing
  public class UltraUserProfile : UserProfile
    public string Email { get; set; }
  public static class Test
    [CommandMethod("test")]
    static public void cmdtest()
      Editor ed = AcadApp.DocumentManager.MdiActiveDocument.Editor;
      // Collection Initializer combined with Object Initializer
      var Up = new List<UltraUserProfile>
        new UltraUserProfile { FName = "Dan", LName = "Marcotte", Email = "NoSpam"},
        new UltraUserProfile { FName = "Luis", LName = "TheMaStEr", Email = "NoSpam"},
      //Object Initializer
      Up.Add(new UltraUserProfile { FName = "Mark", LName = "SwampGod", Email = "NoSpam" });
      //Lambda =>
      Up.ForEach(E => ed.WriteMessage("\n"+E.FName + ", " + E.LName + ", " + E.Email));
Re: C# 3.0 automatic properties
« Reply #1 on: October 30, 2007, 02:50:47 PM »
Me thinks someone at microthoft hath been looking at ruby ....
MickD
« Reply #2 on: October 30, 2007, 06:55:39 PM »
These 'template' things are getting out of hand, they remind me of the over use of macros in C :D
- John Carmack
- J.R.R. Tolkien
« Reply #3 on: October 30, 2007, 07:01:56 PM »
.. did you mean <..> VS2008 (.NET 3.5).
I'm waiting to see LINQ statement used from ACad ...
Interesting example of the lambda statement too Dan.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #4 on: October 31, 2007, 12:53:54 AM »
Hi Kerry,
Actually this is still using the .NET 2.0 framework (VS 2008 can target specific frameworks),
anything that’s in the new “language specification” is compatible with older frameworks (2.0+).
Some of the fun stuff like “Extension methods” and “LinQ” do require the 3.5 framework though.
