(defun c:test (/ bp cnt objname p1 p2 p3 p4 rad ss sse ssex ssl ssnx ssx) (if (setq ss (car (entsel "\nPick a circle object"))) (progn (setq sse (entget ss)) (setq bp (cdr (assoc 10 sse))) (setq rad (cdr (assoc 40 sse))) (setq p1 (polar bp pi rad)) (setq p2 (polar p1 (* pi 1.5) rad)) (setq p3 (polar bp 0 rad)) (setq p4 (polar p3 (* pi 0.5) rad)) (setq ssx (ssget "_w" p2 p4)) (setq ssl (sslength ssx)) (setq cnt 0) (repeat ssl (setq ssnx (ssname ssx cnt)) (setq ssex (entget ssnx)) (setq objname (cdr (assoc 0 ssex))) (alert (strcat "\nThis object is " objname)) (setq cnt (1+ cnt)) ) ; repeat ) ; progn (alert "\nInvalid selected object,try again") ) ; if (princ) ) ; defun
eg.p1 would be the bottom left corner of objects' bbox p1.? where ? is the x, y or z coord typically.cc is the circle centre.v1 is the vector from cc to p1mag1 is the magnitude v1first get v1 (in 2d to keep it short) -v1.x = cc.x - p1.xv1.y = cc.y - p1.ynow calc the magnitude of v1mag1 = sqrt((v1.x*v1.x) + (v1.y*v1.y))now test -if (mag1 < circRadius) return true.hth
;;; -----------------------------------------------------------------;;;; Purpose: move the text inside circle to the center of the circle ;;;; write by qjchen ;;;; http://qjchen.yo2.cn ;;;; http://chenqj.blogspot.com ;;;; -----------------------------------------------------------------;(defun c:test (/ std-sslist movetocenter) (command "_undo" "_be") (setting) (defun std-sslist (ss / n lst) (if (eq 'pickset (type ss)) (repeat (setq n (fix (sslength ss))) ; fixed (setq lst (cons (ssname ss (setq n (1- n))) lst)) ) ) ) (defun movetocenter (/ a x txtobj center_circle outline b bobject objss res midpoint ) (setq a (ssget '((0 . "circle")))) (setq a (std-sslist a)) (foreach x a (setq txtobj nil) (setq pub x) (setq center_circle (assoc 10 (entget x))) (setq outline (objectpoint (entget x))) (setq b (ssget "_cp" outline '((0 . "TEXT")))) (setq bobject (ssname b 0)) (setq objss (vlax-ename->vla-object bobject)) (setq res (xyval1 objss)) (setq midpoint (midp (list (nth 0 res) (nth 1 res)) (list (nth 2 res) (nth 3 res) ) ) ) (command "move" bobject "" midpoint (cdr center_circle)) ) ) (movetocenter) (resetting) (command "_undo" "_e"));;; the subrountine is write by qjchen to get selection by circle;;; and lwpolyline(defun objectpoint (obj / name ori i r w_pl_lst wlist) (setq name (cdr (assoc 0 obj))) (cond ((= name "CIRCLE") (setq ori (cdr (assoc 10 obj))) (setq r (cdr (assoc 40 obj))) (setq i 0) (repeat 30 (setq wlist (append wlist (list (polar ori (* 2 pi (/ i 30.0)) r)) ) ) (setq i (1+ i)) ) ) ((= name "LWPOLYLINE") (defun w_pl_lst (ent / pt_list) (foreach x ent (if (= (car x) 10) (setq pt_list (append (list (cdr x)) pt_list ) ) ) ) pt_list ) (setq wlist (w_pl_lst obj)) ) ) wlist);;; _ end of xyval;;; ---The following codes are copy from Tony Hotchkiss at cadalyst;;; Get the boundingbox of one object(defun xyval1 (obj / minpt maxpt topy bottmy leftx rightx) (vla-GetBoundingBox obj 'minpt 'maxpt) (setq pt1 (vlax-safearray->list minpt) pt2 (vlax-safearray->list maxpt) topy (cadr pt2) bottmy (cadr pt1) leftx (car pt1) rightx (car pt2) ) ; _ end of setq (list leftx bottmy rightx topy));;; The error function(defun err (s) (if (= s "Function cancelled") (princ "\nALIGNIT - cancelled: ") (progn (princ "\nALIGNIT - Error: ") (princ s) (terpri) ) ; _ end of progn ) ; _ end of if (resetting) (princ "SYSTEM VARIABLES have been reset\n") (princ));;; err;;; setting and resetting the system variables(defun setv (systvar newval / x) (setq x (read (strcat systvar "1"))) (set x (getvar systvar)) (setvar systvar newval));;; setv(defun setting () (setq oerr *error*) (setq *error* err) (setv "BLIPMODE" 0) (setv "CMDECHO" 0) (setv "OSMODE" 0));;; setting(defun rsetv (systvar) (setq x (read (strcat systvar "1"))) (setvar systvar (eval x)));;; rsetv(defun resetting () (rsetv "BLIPMODE") (rsetv "CMDECHO") (rsetv "OSMODE") (setq *error* oerr));;; -------------------------------------------------------(defun midp (p1 p2) (mapcar '(lambda (x) (/ x 2.) ) (mapcar '+ p1 p2 ) ));;; The following code taken from Mr.Tony Hotchkiss at Cadalyst(defun err (s) (if (= s "Function cancelled") (princ "\nregion clean - cancelled: ") (progn (princ "\nregion clean - Error: ") (princ s) (terpri) ) ; _ end of progn ) ; _ end of if (resetting) (princ "SYSTEM VARIABLES have been reset\n") (princ));;; err;;; setting and resetting the system variables(defun setv (systvar newval / x) (setq x (read (strcat systvar "1"))) (set x (getvar systvar)) (setvar systvar newval));;; setv(defun setting () (setq oerr *error*) (setq *error* err) (setv "BLIPMODE" 0) (setv "CMDECHO" 0) (setv "OSMODE" 0));;; setting(defun rsetv (systvar) (setq x (read (strcat systvar "1"))) (setvar systvar (eval x)));;; rsetv(defun resetting () (rsetv "BLIPMODE") (rsetv "CMDECHO") (rsetv "OSMODE") (setq *error* oerr))
Are you in HongKong?
