Code Red > .NET
Find if objects are on top of each other (text, attributes)
T.Willey:
I was trying to find a way to find what objects are on top of each other, so I went with the method
'BoundingBoxIntersectWith' to test two entities. It looked like it worked, but upon more testing it doesn't do what I want. Then I went with just the 'IntersectWith' method, but that doesn't work either. I'm at a lose, as I can't use points because they don't always share a point.
Any help is appreciated. Attached is a pic showing my problem; as it returns they do not intersect.
LE:
Tim;
Do not know if we can use from C# the ARX class AcDbMPolygon - in there you will find methods that work for what you are trying to implement.
T.Willey:
--- Quote from: LE on October 29, 2007, 06:55:44 PM ---Tim;
--- End quote ---
Not sure Luis. Let me do some research, and get back to you. Thanks.
Edit: Looks like you can, now to just find out how to use it. Thanks.
LE:
The other, there is one function I wrote in C# it is available in show your stuff to verify if a point is inside of a closed area, if you are looking to check for four points, then, it can be easy to adapt...
Let me check where is that - I'll be back
Here:
http://www.theswamp.org/index.php?topic=17222.msg209140#msg209140
T.Willey:
--- Quote from: LE on October 29, 2007, 06:58:43 PM ---The other, there is one function I wrote in C# it is available in show your stuff to verify if a point is inside of a closed area, if you are looking to check for four points, then, it can be easy to adapt...
Here:
--- End quote ---
I just downloaded it, and was looking at the stuff you and Alexander Rivilis were doing here. I think I will need more time, so I will put this off till tomorrow when I might... might be able to dig into it. Thanks again Luis.
Navigation
[0] Message Index
[#] Next page
Go to full version
