Author Topic: How many lines in a txt file?  (Read 2954 times)
havano
« on: October 29, 2007, 11:24:31 AM »
I want to read lines of an arbitrary txt file into a string array. But I don't want to use Redim Preserve and I don't want to have to open the file twice: once for counting the # of lines and then again, after declaring a string array using the line count for it's index, in order to read the text lines into this array. There should be a "cleaner" method.
My question: is there a standard function that returns the number of lines?
Re: How many lines in a txt file?
« Reply #1 on: October 29, 2007, 12:03:21 PM »
''  Read the entire file into a string variable via a binary get
''  and then use the split function to parse it into a string array.
''  There may be other ways to skin this cat in VBA but I challenge
''  them (invitation extended) to perform faster.
''  Minimalist code, observe --
Sub Test()
    Dim streams() As String
    ''  please use a valid path in the following
    streams = FileToArray("c:\docs\text.txt")
    Debug.Print (UBound(streams) - LBound(streams)) + 1; "line(s) of text retrieved."
End Sub
Function FileToArray(filename As String) As String()
    On Error GoTo errhandler
    Dim handle    As Integer, _
        stream    As String
    handle = FreeFile
    Open filename For Binary As #handle
    stream = Space(LOF(handle))
    Get #handle, , stream
    Close handle
    FileToArray = Split(stream, vbCrLf)
    Exit Function
errhandler:
    Close handle
    Resume exitnow
exitnow:
End Function
havano
« Reply #2 on: October 29, 2007, 02:20:33 PM »
Never saw Split before. Indeed, this solution requires minimal coding. Thanks!
« Reply #3 on: October 29, 2007, 02:29:47 PM »
It's not so much the minimal coding, though I do appreciate the brevity of it, but the performance is darned good -- even on very large files.
A quick test on a text file with 64,000 lines (each 128 chars long) of text was near instantaneous.
Like I said, I'd personally be interested in seeing a vba alternative that out performs it.
Fatty
« Reply #4 on: October 29, 2007, 02:57:23 PM »
Here is my 2 cents, partially stoled from MP :)
Option Explicit
Sub test()
    ''  btw size of localldd.txt is 45.6 Mb
    ''  you can get this file from:
    ''  http://www.gomr.mms.gov/homepg/pubinfo/freeasci/pipeline/freepipe.html
    streams = FileToArray("D:\VBA_TEST\localldd.txt")
End Sub
Function FileToArray(fName As String) As String()
    Dim txt As String
    Dim fs As Object
    Dim fl As Object
    Set fs = CreateObject("Scripting.FileSystemObject")
    Set fl = fs.OpenTextFile(fName)
    txt = fl.ReadAll
    fl.Close
    FileToArray = Split(txt, vbCr)
End Function
~'J'~
havano
« Reply #5 on: October 30, 2007, 09:48:08 PM »
Spasiba. Dasvidanja Fatty!
Fatty
« Reply #6 on: October 31, 2007, 07:26:32 AM »
De nada
Cheers :)
~'J'~
ML
« Reply #7 on: October 31, 2007, 12:24:46 PM »
Hey Guys
That is really cool!
I know there is an obvious need for this or the question would not have been asked but I am wondering how I can expound on this?
ML
« Reply #8 on: October 31, 2007, 12:25:21 PM »
Oh Fatty, also, why the +1?
havano
« Reply #9 on: October 31, 2007, 03:57:50 PM »
Even I can answer that  ;-)
Suppose, you declare an array MyArray (0 to 4). Then the LBound = 0 and the UBound = 4.
Obviously, 4 - 0 = 4. Yet, the array can hold 5 values (index range = 0 1 2 3 4).
Hence the "+ 1".
Glad I could be of some service  :-)
The reason for my question was to achieve maximum speed. So I wanted minimal memory/values reallocation (Redim Preserve) and/or hard drive activity (opening/reading a file twice).
« Last Edit: October 31, 2007, 04:17:29 PM by havano »
