Glenn, I took the liberty to create a folder in the Lilly Pond for you, move your html file and redirect your link. It's not a big deal as you could clearly see that there are a bunch of file that would do well with a better home, but I thought you might like to have your own folder for such purposes. The code looks very nice, however. If you would prefer your folder name to not have caps, I can oblige. As for how it all works, yes it is necessary for a moderator or admin to create a folder for you. You don't however need to have a password or login. That area is intended for admin's only. Just upload your files to your folder. It's quite simple. Just go into your folder before uploading, otherwise your things may end up in the wrong area.
