Author Topic: LispFunction and signaling an error  (Read 13489 times)
LE
Re: LispFunction and signaling an error
« Reply #30 on: October 29, 2007, 05:23:49 PM »
Glenn;
Are you doing a library functions to be use from AutoLisp?
Glenn R
« Reply #31 on: October 29, 2007, 06:44:18 PM »
Luis,
Of course.
Cheers,
Glenn.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #32 on: October 29, 2007, 10:48:43 PM »
Cool,
I think I’m going try the ‘(nil . exception.message) for a while and
see how it works. Here is a sample output
Command: (ADO:Tools "C:\\NewMDB.mdb" "CREATE DATABASE")
(nil . "Database already exists.")
Command: (ADO:Tools "C:\\NewMDB.mdb" "CREATE TABLE Table1 (Name VARCHAR,
Address VARCHAR, Num INTEGE)")
(nil . "Syntax error in field definition.")
Address VARCHAR, Num INTEGER)")
(nil . "Table 'Table1' already exists.")
catch (System.Exception ex)
        result.Add(new TypedValue((int)LispDataType.Nil));
        result.Add(new TypedValue((int)LispDataType.DottedPair));
        result.Add(new TypedValue((int)LispDataType.Text,ex.Message));
      return result;
« Reply #33 on: October 29, 2007, 10:56:56 PM »
Cool,
see how it works. <snip>
Daniel, with the apparent inability to use the 'out' keyword methodology, that seems to be an acceptable way to handle it.
Thanks for the conversation guys ... I'm looking forward to making time to play again.
Chuck Gabriel
« Reply #34 on: May 15, 2008, 09:13:51 AM »
Sorry to resurrect something so long dead, but have there been any new discoveries in this field?
Glenn R
« Reply #35 on: May 15, 2008, 09:30:26 AM »
Not by me Chuck...I gave up in disgust. Someone else might though.
Do you have something to share?
Chuck Gabriel
« Reply #36 on: May 15, 2008, 10:13:33 AM »
Sorry, but no.  I'm just dipping my toes in for the first time and immediately ran into this problem.  If I do come up with something, I'll certainly share it, though.
Glenn R
« Reply #37 on: May 15, 2008, 11:20:40 AM »
The water's fine...jump in! ;)
