Author Topic: [Serializable] not!  (Read 3845 times)
It's Alive!
  • Retired
  • AKA Daniel
[Serializable] not!
« on: October 26, 2007, 01:55:17 AM »
Does anyone know why Autodesk chose not to mark some of the basic types
such as Point3d, Point2d, ObjectId, etc [Serializable]   ?
Re: [Serializable] not!
« Reply #1 on: October 26, 2007, 04:31:39 AM »
Insomniac response so it's probably way out to lunch but - perhaps because they are all primitive data types the overhead / bloat isn't justifiable, in particular because of the cascaded effect upon the object model greater.
« Reply #2 on: October 26, 2007, 05:33:34 AM »
« Reply #3 on: October 26, 2007, 06:18:37 AM »
Hi Daniel .. I'm playing guessing games as well, but Michael's conjecture seems to make sense.
... I'd also guess that the serialization would need to be purpose specific'
..  .. from memory very few of the library classes are Serializable.
There is a .net sample in the ObjectARX SDK called TestFiler.cs demonstrating Object dumping ... but there probably won't be much new stuff there for you :-)
sorry I can't be of help.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #4 on: October 26, 2007, 06:30:59 AM »
Thanks for the replies. I’ll just wrap the objects I need serialized in new serializable objects and/or breakout the primitives I need stored.
MickD
« Reply #5 on: October 26, 2007, 07:58:08 PM »
My guess would be is seeing that acad looks after serialisation itself and the .net lib's are just a wrapper/interface to the 'real' objects it wasn't required...from their point of view of course.
- John Carmack
- J.R.R. Tolkien
It's Alive!
  • Retired
  • AKA Daniel
« Reply #6 on: October 27, 2007, 01:36:17 AM »
Having a little fun here
//(Serialize "c:\\test.dat" "hola")
//(Serialize "c:\\test.dat" '(1 1 1))
//(Serialize "c:\\test.dat" '(1 2 3 1.2 "Wow This is almost cool"))
//(UnSerialize "c:\\test.dat")
//(SaveVars "c:\\test.dat")
//(RestoreVars "c:\\test.dat")
//(defun savevars (path / outlist varlist)
// (setq outlist '())
// (setq varlist '("osmode" "cmdecho" "attdia" "pickstyle"))
// (foreach e varlist
//  (setq outlist (cons (cons e (getvar e)) outlist))
// (Serialize path outlist)
//(defun RestoreVars (path / e inlist)
// (setq inlist (UnSerialize path))
// (if (/=(car inlist) nill)
//  (foreach e inlist
//   (setvar (car e)(cdr e) )
// (princ)
using System;
using System.Runtime.Serialization;
using System.IO;
using System.Runtime.Serialization.Formatters.Binary;
[assembly: CommandClass(typeof(LispSerialization.Commands))]
namespace LispSerialization
  public class Commands
    public Commands()
    [LispFunction("Serialize")]
    static public ResultBuffer dome(ResultBuffer Rb)
      ResultBuffer RetRb = new ResultBuffer();
      try
        TypedValue[] tvArray = Rb.AsArray();
        Stream stream = new FileStream((string)tvArray[0].Value, FileMode.Create);
        try
          List<KeyValuePair<int, Object>>
            kvList = new List<KeyValuePair<int, object>>();
          for (int i = 1; i < tvArray.Length; i++)
            switch ((int)tvArray[i].TypeCode)
              case (int)LispDataType.Point2d:
                  Point2d pt = (Point2d)tvArray[i].Value;
                  kvList.Add(new KeyValuePair<int, object>
                     ((int)LispDataType.ListBegin, null));
                     ((int)LispDataType.Double, pt.X));
                     ((int)LispDataType.Double, pt.Y));
                    ((int)LispDataType.ListEnd, null));
                break;
              case (int)LispDataType.Point3d:
                  Point3d pt = (Point3d)tvArray[i].Value;
                     ((int)LispDataType.Double, pt.Z));
                break;
              case (int)LispDataType.Angle:
              case (int)LispDataType.DottedPair:
              case (int)LispDataType.Double:
              case (int)LispDataType.Int16:
              case (int)LispDataType.Int32:
              case (int)LispDataType.ListBegin:
              case (int)LispDataType.ListEnd:
              case (int)LispDataType.Nil:
              case (int)LispDataType.None:
              //case (int)LispDataType.Orientation:
              case (int)LispDataType.T_atom:
              case (int)LispDataType.Text:
              case (int)LispDataType.Void:
                       ((int)tvArray[i].TypeCode, (object)tvArray[i].Value));
                break;
          IFormatter formatter = new BinaryFormatter();
          formatter.Serialize(stream, kvList);
          RetRb.Add(new TypedValue((int)LispDataType.T_atom));
        finally
          stream.Close();
      catch
        RetRb.Add(new TypedValue((int)LispDataType.Nil));
      return RetRb;
    [LispFunction("UnSerialize")]
    static public ResultBuffer undome(ResultBuffer Rb)
      Stream stream = null;
      try
        stream = new FileStream((string)tvArray[0].Value, FileMode.Open);
        List<KeyValuePair<int, Object>> kvList =
          (List<KeyValuePair<int, Object>>)formatter.Deserialize(stream);
        for (int i = 0; i < kvList.Count; i++)
          RetRb.Add(new TypedValue(kvList[i].Key, kvList[i].Value));
      catch
      finally
        stream.Close();
      return RetRb;
