Actually, I don't really know what's going on. Someone had said something about Autocad still running internally with 16-bits while Windows was at 32, or something or other. It was all muddled. I don't really know what's going on. It's been so long since I've done much with PCs/Windows that I don't really know what the state of the internals is these days. (I've been using mostly Suns and Macs for the last decade...)
I just had some background thoughts along the lines that there might be instances where, for example, things might work if the user entered "100" at the prompt, but not if the user entered "200/2", or something like that. If I seemed to be saying something else, it was probably late-night rambling...
But yeah, once you have a real, it shouldn't change. It's just that, before you get it, you can't really be sure what it's going to be. Therefore, it's unwise to write any code that makes assumptions like "if there's any rounding error, it's going to be in this direction, so if I call functions in this way, I avoid the error...".
