Author Topic: Need help with initial directory  (Read 1198 times)
Eloquintet
« on: October 24, 2007, 09:35:04 AM »
Hey guys,
I got a program that works fine except I just want the initial directory to be Autosave. I know this is probably easy but I can't seem to figure out how to change it to work here. Can somebody help me out?
Public Function GetFileOpen(Title As String, InitFolder As String, Filter As String) As String
  Dim OpenFile As OPENFILENAME
  Dim lReturn As Long
  Dim sFilter As String
  With OpenFile
    .hwndOwner = ThisDrawing.hWnd
    .lStructSize = Len(OpenFile)
    .lpstrFilter = Filter
    .nFilterIndex = 1
    .lpstrFile = String(257, 0)
    .nMaxFile = Len(OpenFile.lpstrFile) - 1
    .lpstrInitialDir = InitFolder
    .lpstrFileTitle = OpenFile.lpstrFile
    .nMaxFileTitle = OpenFile.nMaxFile
    .lpstrTitle = "Select File"
    .flags = 4
    .lpTemplateName = "Test"
  End With
  lReturn = GetOpenFileName(OpenFile)
  If lReturn = 0 Then
    GetFileOpen = ""
  Else
    GetFileOpen = Left$(OpenFile.lpstrFile, InStr(OpenFile.lpstrFile, Chr$(0)) - 1)
  End If
End Function
Dan
AutoCAD Architecture 2015
Bryco
Re: Need help with initial directory
« Reply #1 on: October 24, 2007, 10:00:36 AM »
I don't quite get what you are asking.
The code that you posted, does that give you the name of an open dwg or any dwg?
LE
« Reply #2 on: October 24, 2007, 10:20:51 AM »
No idea.... but:
To:
    .lpstrInitialDir = ThisDrawing.GetVariable("SAVEFILEPATH")
and remove the argument 'InitFolder As String from the function
wait for the vb/a masters
« Reply #3 on: October 24, 2007, 06:57:19 PM »
Luis, that should work ...
Eloquintet
« Reply #4 on: October 25, 2007, 09:27:46 AM »
basically the routine allows you to open bak files then saves them as dwg files and as I would mostly use this to recover autosaves i want it to start there make sense. i'll give it a try and let you know. thanks everybody
Dan
Eloquintet
« Reply #5 on: October 25, 2007, 09:45:58 AM »
Hey,
I got the routine working but when I try to Autoload it as I do all of my other vba routines it gives me this error upon loading
error: bad character read (octal): 21
and if i run it it says macro not found
but if i manually load it it runs fine
What does this error mean?
Dan
Guest
« Reply #6 on: October 25, 2007, 11:42:56 AM »
A quick search on Google suggests that there might be some goofy characters (maybe a linefeed or return or something like that) gumming up the works in your program.
What happens if you click on DEBUG --> COMPILE?  Does it find anything out of the ordinary??
« Reply #7 on: October 27, 2007, 12:32:24 PM »
What is the method you are using for loading the macro?
