Author Topic: Is there a way to insert & update multiple blocks at a time?  (Read 8417 times)
sezbw
« on: October 23, 2007, 10:22:14 PM »
OK so being the block loving nerd I am, I have got myself in a bit of a tricky spot.
I have a whole bunch of blocks (column) in numerous drawing plans ie, C1-800x300, C2-600DIA ETC...
The blocks are saved outside my drawings in a folder.  I have updated these files now I need to re-import them & update them in a load of plans.  Is there a way to insert & update multiple blocks at a time, so I don't have to do them individually.
In the past on swamp I have found a fantastic block swap command, but this time I just want to globally change all blocks of one name to be the same as an external file of the same name.
 :ugly:
Sorry my powers of explanation seem to be failing me...
FengK
Re: Is there a way to insert & update multiple blocks at a time?
« Reply #2 on: October 24, 2007, 03:19:28 AM »
i didn't finish reading the posts in the threads that Alan listed, but it appears to me the lisp commands in those posts are used for replacing block "A" with block "B" which is already in the drawing. and the problem sezbw is trying to solve is different.
don't quote me on this: suppose he has a block named "A" in drawing, and he has another drawing named "A.dwg" which is the new block he wants to replace the old one with. when manually inserting the block (type command "INSERT" and browse that "A.dwg" file), user will be prompted whether to replace the old block definition in drawing or not. but if the block is inserted via lisp, the old block definition will be used.
if what i said above was correct, one way to resolve it would be renaming the old block (to some unique name) in drawing first, inserting the new block, deleting the old block and purging the block definition with the "unique name". this seems to be a good opportunity to use objectDbx.
jbuzbee
« Reply #3 on: October 24, 2007, 07:31:34 AM »
sounds like you should have used xrefs . . .
James Buzbee
Windows 8
Krushert
  • FREE BEER Tomorrow!!
« Reply #4 on: October 24, 2007, 07:41:16 AM »
jbuzbee
« Reply #5 on: October 24, 2007, 08:52:02 AM »
Am I missing something here??
James Buzbee
Windows 8
« Reply #6 on: October 24, 2007, 08:53:20 AM »
Have a look at Post Reply #7 here .. does that suit you ?
http://www.theswamp.org/index.php?topic=9229.msg118979#msg118979
added:
Though you could make a selectionSet of inserted blocks and only replace those from the FolderList ...
« Last Edit: October 24, 2007, 08:56:19 AM by Kerry Brown »
Krushert
« Reply #7 on: October 24, 2007, 09:07:53 AM »
You first statement sounded very opinionated, implying that xrefs is the only way.  That is all.
daron
« Reply #8 on: October 24, 2007, 09:16:58 AM »
That was my first thought as well, that he should have used xrefs. There is an express tool for that purpose, but it's painfully slow. Another thought I also had in regards to xrefs is that if you have multiple xrefs in one drawing you end up with slower load time, so sometimes you are better off not using xrefs. I would assume that would be part of the reasoning for not having used them, but that's just me. They have their purpose, but not at the expense of load times. Wouldn't ODBX be usable here?
jbuzbee
« Reply #9 on: October 24, 2007, 09:28:00 AM »
Before Project Navigator I used to use a routine that would "attach" attributes to an XREF.  Basically you inserted the file first (became a block with attributes), renamed it, then Xrefed it.  Then I used entmod to change the xref to the inserted block and deleted the old reference.  You could attach the drawing as an xref then use something like the following to "point" the existing blocks to the xref: (you'll needd to make sure the two don't share a common name)
(setq block (entget (car(entsel"\nSelect Block")))
      xref-name(cdr(assoc 2(entget(car(entsel "\nSelect Xref"))))))
      (setq new-blk (subst (cons 2 xref-name) (assoc 2 block) block))
      (entmod new-blk)
(warning: this is very bad coding - only used as an illustration!)
James Buzbee
Windows 8
CADaver
« Reply #10 on: October 24, 2007, 10:25:23 AM »
added:
If you select the title link of the specific post in a thread you can paste it here, like this:
http://www.theswamp.org/index.php?topic=9229.msg119393#msg119393
« Reply #11 on: October 24, 2007, 10:36:51 AM »
added:
Yes, I know. All the posts are tied together in my mind .. and I did say reply 7 ... do you think I made it too difficult for the OP ?
CADaver
« Reply #12 on: October 24, 2007, 10:51:11 AM »
added:
Just offering the suggestion that in the time it took you to count the seventh post you could have linked it directly.  Silly of me to interfere.
« Reply #13 on: October 24, 2007, 11:04:02 AM »
« Reply #12 on: Today at 00:51:11 »
.. Silly of me to interfere.
Perhaps it was.
CADaver
« Reply #14 on: October 24, 2007, 11:09:52 AM »
Perhaps it was.
Sometimes suggestions are appreciated, sometimes not.  I'll make a note that Kerry never needs any kind of suggestions, thanks for the heads-up.
