Author Topic: HELP PLEASE! bad argument type: stringp nil  (Read 12605 times)
jermjmm
« on: October 19, 2007, 10:47:24 AM »
having an issue with a program that I've been working on. when i try to run this lisp it says: bad argument type: stringp nil
i've used the same expressions in other lisps and they worked, I don't have a clue as to why it's not working now.
;;; INSERTS TEXT ON LINE
(defun C:Ty (/ A1 A2 A3 E1 E2 E3 ENTNA LASTX OS1 P1 P4 P5 P6 P7 P8 P9 TX TX1)
  (setq OS1 (getvar "osmode"))
  (setvar "osmode" 512)
  (if (= txold "")
    (setq txold "1")
  (setq TX (getstring (strcat "\nEnter text <" txold ">: ")))
  (if (= tx "")
    (setq tx txold)
  (setq txold tx)
  (while (setq E1 (entsel "\nSelect Line: "))
    (setq E2 (entget (car E1)))
    (setq lay (cdr (assoc 8 E2)))
    (command "-layer" "s" lay "")
    (setq E3 (cdr (assoc 0 E2)))
    (setq P1 (cdr E1))
    (setq P1 (car P1))
    (if (= E3 "POLYLINE")
      (setq P2 (cadr E1)
            P3 (getpoint "\nPick point for rotation: ")
      (if (= E3 "CIRCLE")
        (setq P2 (cadr E1)
              P3 (cdr (assoc 10 E2))
        (if (= E3 "ARC")
          (setq P2 (cadr E1)
          (setq P2 (cdr (assoc 10 E2))
                P3 (cdr (assoc 11 E2))
    (if (= E3 "CIRCLE")
      (setq A1 (+ (angle P2 P3) (/ pi 2)))
      (if (= E3 "ARC")
        (setq A1 (angle P2 P3))
    (if (> A1 (/ pi 2))
      (setq A2 (angtos (+ A1 pi) 0 4))
    (if (<= A1 (* pi 1.5))
    (if (<= A1 (/ pi 2))
      (setq A2 (angtos (* A1 1) 0 4))
    (if (> A1 (* pi 1.5))
    (command "TEXT" "M" P1 A2 TX)
    (setvar "osmode" OS1)
    (setq LASTX (entget (entlast)))
    (setq TX1 (textbox LASTX))
    (setq P4 (car TX1))
    (setq P5 (cdr TX1))
    (setq P5 (car P5))
    (setq P6 (distance P4 P5))
    (setq P7 (+ (/ P6 2) (* 0.04 (getvar 'dimscale))))
    (setq A3 (- A1 pi))
    (setq p8 (polar P1 A1 P7))
    (setq p9 (polar P1 A3 P7))
    (command "ERASE" "L" "")
    (command "BREAK" P1 "F" P8 P1)
    (command "BREAK" P1 P9)
    (command "OOPS")
<edit: code tags added>
« Last Edit: October 19, 2007, 11:00:51 AM by CAB »
Re: HELP PLEASE! bad argument type: stringp nil
« Reply #1 on: October 19, 2007, 10:55:01 AM »
Sorry, I don't have time to investigate.
If you define this error handler --
(defun *error* (x) (vl-bt))
-- and then run your program you should be able to quickly determine the source of the problem.
« Reply #2 on: October 19, 2007, 11:05:39 AM »
Try using this:
  (if (or (null txold) (= txold ""))
    (setq txold "1")
jermjmm
« Reply #3 on: October 19, 2007, 11:34:42 AM »
thanks cab!
changed the front end to look like this:
  (if (or (nULL txold) (= txold ""))
    (setq txold "1")
  (if (or (nULL tx) (= tx ""))
    (setq tx TXOLD)
  (setq txold tx)
works great now!
« Reply #4 on: October 19, 2007, 01:56:04 PM »
« Last Edit: October 19, 2007, 02:01:45 PM by Se7en »
jermjmm
« Reply #5 on: October 19, 2007, 02:03:38 PM »
 :-D I figured it would get someone's attention.
« Reply #6 on: October 19, 2007, 02:08:27 PM »
Funny cause I usually ignore threads with titles like that--and if i dont, i wont give any help pertaining to the persons question-. ...I should start giving responses like those thread titles --``RTFM''.
jermjmm
« Reply #7 on: October 19, 2007, 02:10:41 PM »
ah, your no fun. . . just kidding.
« Reply #8 on: October 19, 2007, 02:13:53 PM »
Also funny cause im actually one of the un-serious persons you could ever meet -- 'cept when it comes to thread titles i guess-.
« Reply #9 on: October 19, 2007, 03:22:13 PM »
maybe I'm slow, but I don't see anything wrong with the thread title.....and I coulda swore it's the same now as when I first saw it around 8 this morning (PDT).
jermjmm
« Reply #10 on: October 19, 2007, 03:25:58 PM »
just to let everybody know, i've done some revisions on it and it's working good.  can't say it's the best way to code but then again i've only been learning lisp for about 1 to 2 months.
  (SETQ OLDL (GETVAR "CLAYER"))
    (setq txold "1")
    (setq tx TXOLD)
  (setq txold tx)
   (setq P1 (cadr E1))
      (setq P2 (cadr E1)
            P3 (getpoint "\nPick point for rotation: "))
      (if (= E3 "CIRCLE")
         (setq P2 (cadr E1)
               P3 (cdr (assoc 10 E2)))
         (if (= E3 "ARC")
           (setq P2 (cadr E1)
            P3 (cdr (assoc 11 E2)))
   (if (= E3 "CIRCLE")
      (if (= E3 "ARC")
   (> A1 (/ pi 2))
   (<= A1 (* pi 1.5))
   (setq A1 (+ A1 pi))
   (setq A2 (angtos A1 0 4))
   (setq P4 (car TX1))
   (setq P5 (cdr TX1))
   (setq P5 (car P5))
   (setq A3 (- A1 pi))
   (command "OOPS")
   (SETVAR "CLAYER" OLDL)
<edited to add code tags>
« Last Edit: October 19, 2007, 09:50:05 PM by Keith™ »
« Reply #11 on: October 19, 2007, 08:15:39 PM »
Yep, titles are a pet peeve of mine also.
... along with certain styles of avatar picture  :|
« Reply #12 on: October 19, 2007, 08:17:48 PM »
it's a pity that this good advice appeared to be ignored.
sinc
« Reply #13 on: October 20, 2007, 10:57:36 AM »
Yep.  That backtrace should point right to the problem.
The debugger can be immensely helpful, too, but last I checked, the VLIDE won't pop open to the site of the exception the way VS Express does for .NET programming.  But single-stepping through the code should have turned it up pretty fast, too.
These tools are a programmer's best friend.
« Reply #14 on: October 20, 2007, 11:07:41 AM »
No but Ctrl-F9 [LastBreak] highlites the break.
