I have a simple plot routine that saves hours of plotting time for a person, you simply select the project folder that you want to plot and it plots all of the drawings in that folder for you, the copy count you want, and spools them to the plotter server so that you can simply go back to work in a minute or so.... then when you are ready you simply go to the plotter and pick up your plans....
