Author Topic: Simple question (indefinite points)  (Read 11878 times)
Notsober
Re: Simple question (indefinite points)
« Reply #30 on: October 18, 2007, 05:48:35 PM »
What do you mean your acad wont start?
BTW, did you edit this file in MS Word?
no, I always use notepad....
LE
« Reply #31 on: October 18, 2007, 05:49:38 PM »
great. now my acad won't open!
BTW- I put the lsp in the startup, so that tells me I have to change something. Just before, I did this:
Replaced
(setvar user_layer (getvar "clayer"))
to:
(setq user_layer (getvar "clayer"))
and...
(setvar user_os (getvar "osmode"))
to
(setq user_os (getvar "osmode"))
So now how do I get my ACAD back up and running?
No idea, what you end up doing ?
Remove the lisp from there...  (what it is for you the startup?)
So, you double-click on the ACAD.EXE and does not open it?
« Reply #32 on: October 18, 2007, 05:53:21 PM »
Well the items LE suggested would have NO affect on anything like that, but just to be safe, delete the procedure anyways.
After that, start up acad and change the profile to something else and open a drawing.
Notsober
« Reply #33 on: October 18, 2007, 05:57:20 PM »
Nothing in the routine should have ruined your Acad.  This is just a simple routine to speedup some button pushing.
Standard IT response.... Did you try rebooting?? ... Crazy thing is.. it works most of the time.
hahaha... worked. weird.
In my office: standard IT response - where's the IT guy when you need him?
in other words, we don't have an IT. Just an office manager that knows a little bit about networking, that's all.
thanks for the suggestion, I've never really encountered a situation where all I had to do was reboot.
LE
« Reply #34 on: October 18, 2007, 05:58:10 PM »
and.... can you post/or/upload your code (the file) here.... maybe is something in there.
Notsober
« Reply #35 on: October 18, 2007, 06:00:47 PM »
okay so back to bizness....
I want the routine to:
set layer to CLOUD
turn off ortho
and turn off osnap
finish the routine, then set ortho and osnap back to what they were, whether on or off.
Notsober
« Reply #36 on: October 18, 2007, 06:02:12 PM »
here's what I got so far:
Notsober
« Reply #37 on: October 18, 2007, 06:03:53 PM »
I think it was a gliche or something... our server has been acting up today (it's stormy weather here today).
LE
« Reply #38 on: October 18, 2007, 06:11:18 PM »
Must, be something like that... that routine is a very simple one...
Notsober
« Reply #39 on: October 18, 2007, 06:22:43 PM »
so what's the code for turning ortho off?
(setq user_ortho (getvar "orthomode"))
  (setvar "orthomode" 0)
Or am I not understanding something right?
Notsober
« Reply #40 on: October 18, 2007, 06:26:38 PM »
will this work?
;;Revcloud from spline
(defun C:RS (/ user_layer user_os user_ortho)
    (setvar "clayer" "CLOUD")
    (setvar "osmode" 0)
  (command "_.spline")
  (while (> (getvar "CmdActive") 0)
    (command pause)
  (command "_.revcloud" "o" "l" "n")
  (setvar "clayer" user_layer)
  (setvar "osmode" user_os)
  (setvar "orthomode" user_ortho)
Notsober
« Reply #41 on: October 18, 2007, 06:31:47 PM »
will this work?
    (setvar "osmode" 0)
    (command pause)
OMG! It did work!!
I CAN FISH! YAY!!
« Reply #42 on: October 18, 2007, 06:35:51 PM »
You even added your new variable to the local variable list, nice!  Soon you will be giving others advice on how to fix their routines.
Notsober
« Reply #43 on: October 18, 2007, 06:39:32 PM »
well, I did learn somethin afterall...
lol.
awesome! Thanks so much for the help y'all! Especially Kate M.
I love this forum!
Notsober
« Reply #44 on: October 18, 2007, 06:58:50 PM »
That was actually a guess. Honestly.
I do know a little about programming. Only robotics programming though, so I do understand how to look at the code (or language) and eventually figure it out. Just I don't know anything about VLisp, VBA, or AutoLISP.
But today was a start....
