OK, I definetely got it now and it is doing exactly what the article said
On startup, set the workspace that you want current to be current.
This fixed my toolbar location problem; they are now being retained on each start of ACAD.
I think my earlier approach to the coding was the reason it was not working.
If anyone is interested; here is my approach and code:
Again, for me, it is working just fine.
On Startup, in The acad.dvb file
Sub Acadstartup()
Set AutoCAD = ThisDrawing.Application
RunMacro ("WsCurrent") '<----- This is calling my WsCurrent Module
End Sub
WsCurrent Module:
Sub WsCurrent()
Dim Username As Variant
Dim Preferences As AcadPreferences
Dim ActProfile As String
Dim CurrMenuPath As String
Dim CurrMenuFile As String
Set WshNetwork = CreateObject("WScript.Network")
Set Preferences = ThisDrawing.Application.Preferences
Username = WshNetwork.Username
ActProfile = Preferences.Profiles.ActiveProfile
CurrMenuPath = "C:\Documents and Settings\" & Username & "\Application Data\Autodesk\Autodesk Land Desktop 2006\R16.2\enu\Support\"
CurrMenuFile = Preferences.Files.MenuFile
If ActProfile = "Land Desktop" Then
CurrMenuFile = CurrMenuPath & "land"
ThisDrawing.SetVariable "wscurrent", "Land Destop Complete"
End If
If ActProfile = "MapGeneral" Then
CurrMenuFile = CurrMenuPath & "acmap"
ThisDrawing.SetVariable "wscurrent", "Map Classic"
End If
End Sub
