Author Topic: VP on layer  (Read 1743 times)
David Hall
  • Automatic Duh Generator
VP on layer
« on: October 15, 2007, 02:44:12 PM »
Does anyone know how to manipulate a VP's layer thru code?  This does not work
      Dim objViewport As AcadViewport
      For Each objViewport In ThisDrawing.Viewports
      objViewport.Layer = "DEFPOINTS"
      Next objViewport
Guest
Re: VP on layer
« Reply #1 on: October 15, 2007, 03:01:44 PM »
I've used the following code for something similar.... locking all viewports.
I added the 'layer = Defpoints' and it still works fine.
There's probably a better way than what I'm doing, but hey... if it ain't broke.
Public Sub x()
    Dim FilterType(0) As Integer
    Dim FilterData(0) As Variant
    Dim sset As AcadSelectionSet
    Dim objVP As AcadPViewport
    Dim x As Integer
    FilterType(0) = "0"
    FilterData(0) = "VIEWPORT"
    Set sset = vbdPowerSet("VPUpdate")
    sset.Select acSelectionSetAll, , , FilterType, FilterData
    For x = 0 To sset.Count - 1
        Set objVP = sset(x)
        objVP.Layer = "Defpoints"
        objVP.DisplayLocked = True
    Next x
End Sub
Private Function vbdPowerSet(strName As String) As AcadSelectionSet
    Dim objSelSet As AcadSelectionSet
    Dim objSelCol As AcadSelectionSets
    Set objSelCol = ThisDrawing.SelectionSets
    For Each objSelSet In objSelCol
        If objSelSet.Name = strName Then
            objSelSet.Delete
            Exit For
        End If
    Next
    Set objSelSet = ThisDrawing.SelectionSets.Add(strName)
    Set vbdPowerSet = objSelSet
End Function
David Hall
Re: VP on layer
« Reply #2 on: October 15, 2007, 03:04:04 PM »
DUH, I am such an Idiot, I didn't use AcadPViewport
thanks
« Last Edit: October 15, 2007, 03:05:39 PM by CmdrDuh »
