Author Topic: template advice  (Read 7902 times)
template advice
« Reply #30 on: July 28, 2004, 09:02:59 AM »
Thanks Daron. The reason I asked is because I'm working on a bunch of functions that read/write to the dwg summary object. that's the dialog you see when you go to file->drawing properties then select Summary. Starting in 2004 it's a lot easier to get to. That's what blockwerx uses, as you can see in the previous posts.
