Author Topic: template advice  (Read 7754 times)
M-dub
template advice
« Reply #15 on: July 27, 2004, 11:10:19 AM »
Preferences > Attributes tab > select or deselect "Use Blockwerx Attribute dialog when inserting"
template advice
« Reply #16 on: July 27, 2004, 11:10:33 AM »
Dan, is adt 3.3 2004 compatible?
hendie
template advice
« Reply #17 on: July 27, 2004, 11:12:17 AM »
sorry, I don't understand the question....
ELOQUINTET
template advice
« Reply #18 on: July 27, 2004, 11:18:36 AM »
ok 1 question at a time i'll ask about attributes later. i dragged the custom lines but how do i fill them in like you have done.
xxxxxxx
xxxxxxx
xxxxxxx
xxxxxxx
yes mark it seems to be compatible
hendie
template advice
« Reply #19 on: July 27, 2004, 11:26:55 AM »
open the drawing (CONTROL+O in Blockwerx)
go to File ~ Drawing Properties
and fill in properties to your hearts content ~ then just call up those properties in the Blockwerx dialogues
me thinks we need a tutorial on using Blockwerxhere at the swamp
M-dub
template advice
« Reply #20 on: July 27, 2004, 11:30:01 AM »
Good Idea!
ELOQUINTET
template advice
« Reply #21 on: July 27, 2004, 11:44:21 AM »
yeah that's really all i want is to be able to give description. so there's no way to do that without forkin over the 50 bucaroos  :cry:
hendie
template advice
« Reply #22 on: July 27, 2004, 11:50:56 AM »
$50 for all that functionality is a very very small price to pay !
you could also do it in design center (sort of) but the functionality is really limited compared to Blockwerx.
M-dub
template advice
« Reply #23 on: July 27, 2004, 11:55:18 AM »
Offer to buy it if your boss won't.  The offer alone might change his mind.  Tell him that you could get some of the same results as BlockWerx, but it would take you at least 4 hours of work...(hopefully you're worth more than $50 for 4 hours!!!)
If the boss won't buy it, tell him you're going to and it comes with you if you ever leave the company.
ELOQUINTET
template advice
« Reply #24 on: July 27, 2004, 12:21:36 PM »
ok having said that what can i do with the atribute editor, how is it different from plain autocad?
PDJ
template advice
« Reply #25 on: July 27, 2004, 12:47:25 PM »
You've been fiddling with this thing over a 3 hour period already based on your posts..  Looks to me like it would be worth your time to invest in the program.. I'll bet your employer bills you out at over $65/hr.. Time for him to open the wallet I'd say..
M-dub
template advice
« Reply #26 on: July 27, 2004, 12:53:32 PM »
In Acad, set attdia to 1 and in blockwerx, make sure you have it selected, then insert a block.  There's really no big difference other than the fact that after you fill in the attributes, you don't have to TAB to the OK button like you do in the acad dialog box.
hendie
template advice
« Reply #27 on: July 28, 2004, 04:23:54 AM »
Quote from: PDJ
applause inserted here  :dood:
hendie
template advice
« Reply #28 on: July 28, 2004, 07:05:43 AM »
Quote from: M-dub
Good Idea!
okay guys.. get your blockwerx tutorial now while it's hot (in CHM format)
it's only a quickie but should give enough info to get started
daron
template advice
« Reply #29 on: July 28, 2004, 08:45:12 AM »
Quote from: Mark Thomas
Mark, sort of. If you draw in ADT4, which is 2004, and save back to ADT3.3, which is 2002, you get proxy objects. I hate those things and I don't suppose I need to explain them to you. Needless to say, they are uneditable pieces of trash. I assume that's why you asked. Now, if you export your drawing from adt4 to adt3.3 you can get real objects, if I remember correctly. At least I know you can edit the objects. Anyway, going deeper, if you are looking to a lisp solution, yes they are compatible with the same issues as any 2004 to 2002 releases.
