I had to put my events in the This drawing module. BRB
edit: Added code
I must give someone else credit for this, but off the top of my head, I can't remember who helped me with this. Maybe Bryco ?? Anyway, I'll go look in a minute. Here is what they gave me to fix that app level event for end open
Option Explicit
Public WithEvents AutoCAD As AcadApplication
Sub App_StartMacro()
Set AutoCAD = ThisDrawing.Application
End Sub
Private Sub AcadDocument_BeginCommand(ByVal CommandName As String)
If CommandName = "COMMANDLINE" Then
End If
End Sub
Private Sub AutoCAD_EndOpen(ByVal FileName As String)
ThisDrawing.SetVariable "INSUNITS", 1
ThisDrawing.SetVariable "OSNAPZ", 1
ThisDrawing.SetVariable "LAYEREVAL", 0
ThisDrawing.SetVariable "LAYERNOTIFY", 0
Dim strUser As String
strUser = UCase(Environ("USERNAME"))
Select Case strUser
Case "UA02038"
Case "UA03347"
Case Else
ThisDrawing.SendCommand "undefine" & vbCr & "BEDIT" & vbCr
End Select
End Sub
Public Sub AcadStartup()
Dim Preferences As AcadPreferences, intOsmode As Integer
Set Preferences = ThisDrawing.Application.Preferences
Select Case strUser
Case "UA02038"
Preferences.Selection.PickFirst = True
intOsmode = 71
ThisDrawing.SetVariable "ORTHOMODE", 1
Case "UA03347"
intOsmode = 19
Case Else
intOsmode = 7
End Select
If intOsmode = 0 Then
ThisDrawing.SetVariable "osmode", 3
Else
ThisDrawing.SetVariable "osmode", intOsmode
End If
Application.Preferences.Output.AutomaticPlotLog = False
Application.Preferences.User.ADCInsertUnitsDefaultSource = acInsertUnitsInches
Application.Preferences.User.ADCInsertUnitsDefaultTarget = acInsertUnitsInches
End Sub
End open wasn't available out of the box, but after these tweaks, it is
