I just use an old copy of burst that automatically selects all, thanks to CAB showing me how to do it.
Placed it into my support directory. The only reason is I can retain some objects like fixtures etc... while removing bound blocks of entire rooms. I just set the number of times to run the routine depnding on how nested the XREF's were before binding when I setup the background files.
(Defun C:MYBURST (/ item bitset bump att-text lastent burst-one burst
BCNT BLAYER BCOLOR ELAST BLTYPE ETYPE PSFLAG ENAME )
; Item from association list
(Defun ITEM (N E) (CDR (Assoc N E)))
; Error Handler
(acet-error-init
(list
(list "cmdecho" 0
"highlight" 1
T ;flag. True means use undo for error clean up.
);list
);acet-error-init
; BIT SET
(Defun BITSET (A B) (= (Boole 1 A B) B))
; BUMP
(Setq bcnt 0)
(Defun bump (prmpt)
(Princ
(Nth bcnt '("\r-" "\r\\" "\r|" "\r/"))
(Setq bcnt (Rem (1+ bcnt) 4))
; Convert Attribute Entity to Text Entity
(Defun ATT-TEXT (AENT / TENT ILIST INUM)
(Setq TENT '((0 . "TEXT")))
(ForEach INUM '(8
6
38
39
62
67
210
10
40
1
50
41
51
7
71
72
73
11
74
(If (Setq ILIST (Assoc INUM AENT))
(Setq TENT (Cons ILIST TENT))
(Setq
tent (Subst
(Cons 73 (item 74 aent))
(Assoc 74 tent)
tent
(EntMake (Reverse TENT))
; Find True last entity
(Defun LASTENT (/ E0 EN)
(Setq E0 (EntLast))
(While (Setq EN (EntNext E0))
(Setq E0 EN)
E0
; See if a block is explodable. Return T if it is,
; otherwise return nil
(Defun EXPLODABLE (BNAME / B expld)
(setq BLOCKS (vla-get-blocks
(vla-get-ActiveDocument (vlax-get-acad-object)))
(vlax-for B BLOCKS (if (and (= :vlax-false (vla-get-islayout B))
(= (strcase (vla-get-name B)) (strcase BNAME)))
(setq expld (= :vlax-true (vla-get-explodable B)))
expld
; Burst one entity
(Defun BURST-ONE (BNAME / BENT ANAME ENT ATYPE AENT AGAIN ENAME
ENT BBLOCK SS-COLOR SS-LAYER SS-LTYPE mirror ss-mirror
mlast)
(Setq
BENT (EntGet BNAME)
BLAYER (ITEM 8 BENT)
BCOLOR (ITEM 62 BENT)
BBLOCK (ITEM 2 BENT)
BCOLOR (Cond
((> BCOLOR 0) BCOLOR)
((= BCOLOR 0) "BYBLOCK")
("BYLAYER")
BLTYPE (Cond ((ITEM 6 BENT)) ("BYLAYER"))
(Setq ELAST (LASTENT))
(If (and (EXPLODABLE BBLOCK) (= 1 (ITEM 66 BENT)))
(Progn
(Setq ANAME BNAME)
(While (Setq
ANAME (EntNext ANAME)
AENT (EntGet ANAME)
ATYPE (ITEM 0 AENT)
AGAIN (= "ATTRIB" ATYPE)
(bump "Converting attributes")
(ATT-TEXT AENT)
(Progn
(bump "Exploding block")
(acet-explode BNAME)
;(command "_.explode" bname)
(Setq
SS-LAYER (SsAdd)
SS-COLOR (SsAdd)
SS-LTYPE (SsAdd)
ENAME ELAST
(While (Setq ENAME (EntNext ENAME))
(bump "Gathering pieces")
(Setq
ENT (EntGet ENAME)
ETYPE (ITEM 0 ENT)
(If (= "ATTDEF" ETYPE)
(Progn
(If (BITSET (ITEM 70 ENT) 2)
(ATT-TEXT ENT)
(EntDel ENAME)
(Progn
(If (= "0" (ITEM 8 ENT))
(SsAdd ENAME SS-LAYER)
(If (= 0 (ITEM 62 ENT))
(SsAdd ENAME SS-COLOR)
(If (= "BYBLOCK" (ITEM 6 ENT))
(SsAdd ENAME SS-LTYPE)
(If (> (SsLength SS-LAYER) 0)
(Progn
(bump "Fixing layers")
(Command
"_.chprop" SS-LAYER "" "_LA" BLAYER ""
(If (> (SsLength SS-COLOR) 0)
(Progn
(bump "Fixing colors")
(Command
"_.chprop" SS-COLOR "" "_C" BCOLOR ""
(If (> (SsLength SS-LTYPE) 0)
(Progn
(bump "Fixing linetypes")
(Command
"_.chprop" SS-LTYPE "" "_LT" BLTYPE ""
; BURST MAIN ROUTINE
(Defun BURST (/ SS1)
(setq PSFLAG (if (= 1 (caar (vports)))
1 0
;(setq ss1 (ssget "_X" ))
(Setq SS1 (SsGet "_X" (list (cons 0 "INSERT")(cons 67 PSFLAG))))
(If SS1
(Progn
(Setvar "highlight" 0)
(terpri)
(Repeat
(SsLength SS1)
(Setq ENAME (SsName SS1 0))
(SsDel ENAME SS1)
(BURST-ONE ENAME)
(princ "\n")
; BURST COMMAND
(BURST)
(acet-error-restore)
);end defun
