Author Topic: Automatically Select (highlight) Listbox Item  (Read 15247 times)
Guest
« on: October 04, 2007, 09:47:17 AM »
I've also posted over here, but thought I'd ask here as well since this site gets more attention.
So here goes...
How can I automatically select a listbox item and highlight it?  I only know the text of the item, not it's number (location) in the list.
Thanks.
ASMI
Re: Automatically Select (highlight) Listbox Item
« Reply #1 on: October 04, 2007, 10:16:38 AM »
Method SetSel
This method will set the indicated list item in a multiple selection ListBox as selected or unselected.
AutoLISP Syntax:
(dcl_ListBox_SetSel Text_Numbering_V1_0_Form1_ListBox23
   nIndex [as Integer]
   nIsSelected [as Integer: 0 = Not Selected, 1 = Selected])
I don't undersand because there is three forums 'VisualDCL Programming', 'OpenDCL' and 'ObjectDCL'? What for 'VisualDCL Programming'?
Guest
« Reply #2 on: October 04, 2007, 10:26:16 AM »
Method SetSel
AutoLISP Syntax:
   nIndex [as Integer]
Thanks but I don't know what number the text is in the list so the Integer piece is useless to me right now until I can determine where in the list the text resides - unless I'm missing something.
ASMI
« Reply #3 on: October 04, 2007, 10:45:01 AM »
To find Index of text string use FindStringExact method, then select it with SetSel method.
Method FindStringExact as Integer
This method finds the first string in a ListBox that contains a list item with the exact string match without changing the ListBox selection. A search for "Example Text" will find "Example Text". Use the dcl_ListBox_SelectString function instead to both find and select a string.
AutoLISP Syntax:
(Setq rValue (dcl_ListBox_FindStringExact Text_Numbering_V1_0_Form1_ListBox23
   SearchString [as String]))
« Reply #4 on: October 04, 2007, 11:15:19 AM »
AutoLISP Syntax:
or use dcl_ListBox_SelectString (see bolded and enlarge sized line in quote above, by me)
Guest
« Reply #5 on: October 04, 2007, 11:26:14 AM »
AutoLISP Syntax:
'snot working, man!  What version are you running?  I've got 4.0.2.4.
BazzaCAD
« Reply #6 on: October 04, 2007, 12:35:00 PM »
Wow you're way out of date dude.
The current stable version is 4.0.3.1 & the experimental 4.1 alpha version is 4.1.0.9.
You should at least update to 4.0.3.1 https://sourceforge.net/project/showfiles.php?group_id=187950&package_id=220267&release_id=482977
BazzaCAD
« Reply #7 on: October 04, 2007, 12:40:26 PM »
This post should actually be in the "OpenDCL" forum, since thats what is seams you're asking about...
"ObjectDCL" is anther product.
"VisualDCL Programming" is for stuff like using VBA forms with Lisp or just basic DCL forms.
ASMI
« Reply #8 on: October 04, 2007, 01:38:17 PM »
> Matt W
'snot working, man!
Do you really think that?
>BazzaCAD
I know it, because pay for it 300$ aproximetely 3 years ago. But this product (in that time) had too many bags with Atocad crach :( I have some programs on it (for my own and my friends usage), but can't offer it to other people.
Now it's clear for me.
Guest
« Reply #9 on: October 04, 2007, 01:40:28 PM »
> Matt W
'snot working, man!
Can you post a short, working example because what I've got isn't working.
« Reply #10 on: October 04, 2007, 02:32:40 PM »
I just peeked in here, and saw what was posted, and you question.  I don't use OpenDcl .... so I'm no much help in this forum.  :roll:
owenwengerd
« Reply #11 on: October 04, 2007, 05:30:23 PM »
Matt, try installing the latest version of OpenDCL and let us know whether you still have the problem.
ASMI
« Reply #12 on: October 04, 2007, 05:32:12 PM »
There is short example.
ASMI
« Reply #13 on: October 04, 2007, 05:33:27 PM »
Yes, it is latest 4.1 Alpha 9.
Guest
« Reply #14 on: October 05, 2007, 01:23:28 PM »
Can you post it as a ZIP instead of a RAR?
