Author Topic: OpenDCL 4.1 Alpha 9  (Read 3328 times)
OpenDCL 4.1 Alpha 9
« on: October 01, 2007, 06:45:08 PM »
https://sourceforge.net/forum/message.php?msg_id=4545501
By: owenwengerd
Alpha 9 has only a few bug fixes, and no major changes as things begin to shift
into beta mode. I expect one or two more alpha releases, then 4.1 will enter
the beta phase. If you're still using OpenDCL 4.0, now would be a good time
to test your existing projects in 4.1 to ensure that any problems get addressed
before 4.1 is released.
Download :
https://sourceforge.net/project/showfiles.php?group_id=187950
ASMI
Re: OpenDCL 4.1 Alpha 9
« Reply #1 on: October 02, 2007, 01:20:15 AM »
Thanks for the information, I recently download Alpha 8 and here already Alpha 9. I see that the group of developers do active work. I hope that soon we get the final product. I now do one program using OpenDCL 4.1, unfortunately there is not enough time.
