Author Topic: To Know when user cancels the routine in Error Handling  (Read 2633 times)
Arun Raj
« on: July 24, 2004, 02:43:57 AM »
« Reply #1 on: July 24, 2004, 04:23:19 AM »
Lookup vl-catch-all-apply.
example:
returns nil or real
(defun MST-Getreal (msg / r)
    (and
      (= (type msg) 'STR)
      (not
        (vl-catch-all-error-p
          (setq r (vl-catch-all-apply 'getreal (list msg)))
        ); not
    r
    ); if
  ); defun
« Reply #2 on: July 24, 2004, 08:05:38 AM »
This is the way I approach it, I borrowed this code from stig
some time back.
You will notice at the end of the routine *error* ""
this flags the normal exit and the error routine is used to reset
variables changed during start up.
Also note "console break" "Function cancelled" "quit / exit abort"
any of those messages are caused by the user pressing ESCAPE.
(defun c:mainroutine (/ *error* useror useros usercmd)
  ;; error function & Routine Exit
  (defun *error* (msg)
      (not
(member
 msg
 '("console break" "Function cancelled" "quit / exit abort" "")
    ) ; endif
    ;;reset all variables here
    (setvar "orthomode" useror)
    (setvar "osmode" useros)
    (setvar "CMDECHO" usercmd)
  ) ;end error function
;;;                       Main Routine
  (setq usercmd (getvar "CMDECHO"))
  (setvar "CMDECHO" 0)
  (setq useros (getvar "osmode"))
  (setq useror "orthomode")
  ;;       Your code goes here
  ;; End of main routine and exit
  (*error* "") ; call error routine to reset vars
  (princ)  ; exit quietly
) ; end defun
« Reply #3 on: July 24, 2004, 11:22:43 AM »
Did you ask them? ...That's what i do.
SMadsen
« Reply #4 on: July 24, 2004, 04:44:13 PM »
LOL
