Author Topic: Remove Duplicates from list?  (Read 17576 times)
Marc'Antonio Alessi
  • Marco
Re: Remove Duplicates from list?
« Reply #30 on: March 14, 2022, 09:16:17 AM »
(defun :LST-REMOVE-DUPLICATES (l / r)
   (while (setq i (car l) )  (setq r (cons i r)   l (vl-remove i l)   )   )
   (reverse r)
this one seems to be faster
you need to declare "i" as local...
; Function: ALE_RemoveDupOnLst2
; Version 1.00 - 9 Apr 2003
; Description:
;   removes all the duplicated elements leaving originals,
;   faster on lists with high number of duplicates
;   For example:
;   (setq alist nil) (setq alist2 '(1 2 3 4 4 5 5 5 6 7 8 9 9 9 9))
;   (setq alist (repeat 500 (setq alist (append alist alist2))))
; Arguments:
;   In_Lst = A list
(defun ALE_RemoveDupOnLst2 (In_Lst / OutLst CarElm)
  (while In_Lst
    (setq
      In_Lst (vl-remove (setq CarElm (car In_Lst)) (cdr In_Lst))
      OutLst (cons CarElm OutLst)
  (reverse OutLst)
Marc'Antonio Alessi
  • Marco
« Reply #31 on: March 14, 2022, 09:22:13 AM »
; Marc'Antonio Alessi
; Function: ALE_RemoveDupOnLst14
; Version 1.00 9 Apr 2003
; Description:
;   for R14
; Arguments:
;   In_Lst = A list
(defun ALE_RemoveDupOnLst14 (In_Lst / OutLst)
  (reverse
    (foreach ForElm In_Lst
      (if (member ForElm OutLst)
        OutLst
        (setq OutLst (cons ForElm OutLst))
domenicomaria
« Reply #32 on: March 14, 2022, 09:55:46 AM »
(setq l '(0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54) )
(setq l (append l l l l l l l) )
(ALE_REMOVEDUPONLST2 L)........390 / 1.0428 <slowest>
(:LST-REMOVE-DUPLICATES L).....374 / 1.0000 <FASTEST>
because there is no need of
(cdr In_Lst)
if you add CarElm to OutLst
BEFORE !
VovKa
  • Ukraine
« Reply #33 on: March 14, 2022, 10:52:39 AM »
(:LST-REMOVE-DUPLICATES '(1 nil 2 3))
Marc'Antonio Alessi
  • Marco
« Reply #34 on: March 14, 2022, 11:50:38 AM »
(cdr In_Lst)
BEFORE !
(defun ALE_RemoveDupOnLst2 (L / o e)
  (while L
    (setq
      L (vl-remove (setq e (car L)) (cdr L))
      o (cons e o)
  (reverse o)
(Benchmark '(
(ALE_RemoveDupOnLst2 l)
(:LST-REMOVE-DUPLICATES l)
--- Benchmark utility: In memory of Michael Puckett ---
Elapsed milliseconds / relative speed for 2048 iteration(s):
    (ALE_REMOVEDUPONLST2 L)........1437 / 1.01 <fastest>
    (:LST-REMOVE-DUPLICATES L).....1438 / 1.01
    (ALE_REMOVEDUPONLST2 L)........1453 / 1
    (:LST-REMOVE-DUPLICATES L).....1453 / 1 <slowest>
Marc'Antonio Alessi
  • Marco
« Reply #35 on: March 14, 2022, 11:53:40 AM »
BricsCAD V22
Elapsed milliseconds / relative speed for 8192 iteration(s):
    (ALE_REMOVEDUPONLST2 L)........1062 / 1.03 <fastest>
    (ALE_REMOVEDUPONLST2 L)........1078 / 1.01
    (:LST-REMOVE-DUPLICATES L).....1094 / 1
    (:LST-REMOVE-DUPLICATES L).....1094 / 1 <slowest>
Marc'Antonio Alessi
  • Marco
« Reply #36 on: March 14, 2022, 12:03:26 PM »
Maybe a VERY little faster...
(defun ALE_RemoveDupOnLst4 (L / o e)
 (reverse
  (while L
    (setq
      o (cons e o)
domenicomaria
« Reply #37 on: March 14, 2022, 12:55:27 PM »
(defun :LST-REMOVE-DUPLICATES (l / i r)
   (while (or (setq i (car l) ) (setq l (cdr l) ) )  (setq r (cons i r)   l (vl-remove i l) ) )
   (reverse r)
This one, seems to work, but it is not faster.
... The truth is that you are always right !  :-)
domenicomaria
« Reply #38 on: March 14, 2022, 02:01:52 PM »
found my way to here from a faraway thread
mine:
(defun vk_RemoveDupl
     (InList / OutList First)
  (while InList
    (setq First   (car InList)
  InList  (cdr InList)
  OutList (cons First OutList)
    (if (vl-position First InList)
      (setq InList (vl-remove First InList))
  (reverse OutList)
it's slower that gile's recursive one, but has no "19975" limitation.
I know that when you do something,
there is always a good reason.
So let me to understand :
why do you use vl-position?
I believe that
vl-remove contains within it a function like vl-position. . . .
because before removing an element
it must check if it is present in the list,
and what is/are the position/s . . .
(because vl-remove removes ALL the items to remove)
so what's the point of using vl-position before vl-remove?
domenicomaria
« Reply #39 on: March 14, 2022, 02:30:00 PM »
   (reverse r)
However this code is still wrong,
because if there is only one NIL and it is the last element,
it is removed anyway, even though it is not a duplicate . . .
VovKa
  • Ukraine
« Reply #40 on: March 14, 2022, 03:02:21 PM »
domenicomaria
« Reply #41 on: March 15, 2022, 03:05:50 AM »
i explained it in this post https://www.theswamp.org/index.php?topic=19128.msg288827#msg288827
You are right !
I made these the following 2 tests only with your function :
vk_RemoveDupl
and
vk_RemoveDupl_2 (where I have removed vl-position)
  1. (defun vk_RemoveDupl
  2.                                                         (InList / OutList First)
  3.         (while InList
  4.                 (setq   First     (car InList)
  5.                                 InList  (cdr InList)
  6.                                 OutList (cons First OutList)
  7.                 )
  8.                 (if (vl-position First InList)
  9.                         (setq InList (vl-remove First InList))
  10.                 )
  11.         )
  12.         (reverse OutList)
  13. )
  14.
  15. . . . . .
  16.
  17. (defun vk_RemoveDupl_2
  18.                                                           (InList / OutList First)
  19.         (while InList
  20.                 (setq   First     (car InList)
  21.                                 InList  (cdr InList)
  22.                                 OutList (cons First OutList)
  23.                 )
  24.                 (setq InList (vl-remove First InList))
  25.         )
  26.         (reverse OutList)
  27. )
  28.
(setq mylst nil   i 0)
(repeat 1000 (setq mylst (cons (setq i (1+ i)) mylst)))
(benchmark '((vk_RemoveDupl mylst) (vk_RemoveDupl_2 mylst)))
Elapsed milliseconds for 80 iteration(s)/ relative Timing :
(VK_REMOVEDUPL_2 MYLST).....5039 / 20.1560 <slowest>
(VK_REMOVEDUPL MYLST)........250 / 1.0000 <fastest>
(setq mylst (append mylst mylst mylst mylst mylst mylst ) )
(now mylst contains duplicates . . .)
Elapsed milliseconds for 5 iteration(s)/ relative Timing :
(VK_REMOVEDUPL MYLST).......1794 / 1.0176 <slowest>
(VK_REMOVEDUPL_2 MYLST).....1763 / 1.0000 <fastest>
So the result depends from the "type" of the list ...
... and because vl-position finds only the first position
while vl-remove, before removing something, has to find all the positions
VovKa, You are always right !  :-)
VovKa
  • Ukraine
« Reply #42 on: March 15, 2022, 08:18:25 AM »
this is absolutely correct
that is why it would be good to have both variants in one's library and use the appropriate
ribarm
  • Marko Ribar, architect
« Reply #43 on: March 27, 2022, 05:05:20 AM »
Another one :
https://www.cadtutor.net/forum/topic/74677-lisp-for-total-line-length-for-lines-which-in-every-separately-box/?do=findComment&comment=591483
Something like :
  1. (setq lst '("box1" "box1" "box1" "box2" "box2" "box3" "box3"))
  2. (defun mr_RemoveDupl (InList fuzz)
  3.   (vl-remove-if-not
  4.     (function
  5.       (lambda ( x )
  6.         (if
  7.           (vl-some
  8.             (function
  9.               (lambda ( y )
  10.                 (equal x y fuzz)
  11.               )
  12.             ) InList
  13.           )
  14.           (progn
  15.             (setq InList
  16.               (vl-remove-if
  17.                 (function
  18.                   (lambda ( y )
  19.                     (equal x y fuzz)
  20.                   )
  21.                 ) InList
  22.               )
  23.             )
  24.             x
  25.           )
  26.         )
  27.       )
  28.     ) InList
  29.   )
  30. )
  31. (mr_RemoveDupl lst 0) => ("box1" "box2" "box3")
  32.
This one is for benchmark testing :
  2. (defun mr_RemoveDupl (InList fuzz / x r )
  3.   (while (setq x (car InList))
  4.     (setq InList
  5.       (vl-remove-if
  6.         (function
  7.           (lambda ( y )
  8.             (equal x y fuzz)
  9.           )
  10.         ) InList
  11.       )
  12.     )
  13.     (setq r (append r (list x)))
  14.   )
  15. )
  16. (mr_RemoveDupl lst 0) => ("box1" "box2" "box3")
  17.
« Last Edit: March 27, 2022, 08:30:34 AM by ribarm »
M.R. on Youtube
