Author Topic: Ignore Z value  (Read 1968 times)
David Hall
  • Automatic Duh Generator
Ignore Z value
« on: September 27, 2007, 04:04:43 PM »
In 2008, has anyone found a programmic way to set the option for ignoring Z values?
from the help file
Replace Z Value with Current Elevation
Specifies that object snaps ignore the Z-value of the object snap location and use the Z-value of the elevation set for the current UCS.
I want to add this to the startup of every user, but cant find it.  I have looked here so far
Application.Preferences.Drafting but haven't found it yet.  Other options from the Drafting Tab in "Options" are there, just not this one.
David Hall
Re: Ignore Z value
« Reply #1 on: September 27, 2007, 04:05:47 PM »
Nevermind, just found it as OSNAPZ=1
Apprently you have to use ThisDrawing.SetVariable to set it
« Last Edit: September 27, 2007, 04:07:34 PM by CmdrDuh »
