[HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R17.1\ACAD-6006:409\Applications\InfoCenterAcConn]"LOADCTRLS"=dword:00000000"LOADER"="C:\\Program Files\\AutoCAD MEP 2008\\AcInfoCenterConn.DLL""DESCRIPTION"="AutoCAD InfoCenterAcConn addin""MANAGED"=dword:00000001
(setq HKLM (strcat "HKEY_LOCAL_MACHINE\\" (vlax-product-key) "\\Applications\\InfoCenterAcConn" ) ) (vl-registry-write HKLM "LOADCTRLS" XXX) (vl-registry-write HKLM "LOADER" XXX) (vl-registry-write HKLM "DESCRIPTION" XXX) (vl-registry-write HKLM "MANAGED" XXX)
If you are deleting registry keys, you can use the - path like so to take em all out at once ...
Deleting files or keys usually causes more hangs, especially when the main profile uses a network based customization structure.I didn't delete, I just set one key to Zero. If only it were that easy to add zero's to my paycheck :ugly:
(vl-registry-write (strcat "HKEY_LOCAL_MACHINE\\" (vlax-product-key) "\\Applications\\InfoCenterAcConn" ) "LOADCTRLS" 0)
