Author Topic: Text Box - OnKillFocus do not work...  (Read 3884 times)
ASMI
« on: September 24, 2007, 07:26:45 AM »
Many thanks friends for creation OpenDCL, I is simple in delight from its work, :roll: but has faced a small problem. I hope that you eliminate it or specify in what I is not right.
I try to use new OpenDCL Studio V 4.1.0.7 with AutoCAD 2007 and seems found one small bag. I need to restrict input of negative and zero values in Text Box (with NumericUnitsFilter). For the reason that function FilterStringCollection yet does not work I has decided to use event OnKillFocus for check of correctness of the entered value, however events OnKillFocus and SetFocus why that do not work on my PC  :cry:
Once again many thanks!
owenwengerd
Re: Text Box - OnKillFocus do not work...
« Reply #1 on: September 24, 2007, 12:05:34 PM »
...however events OnKillFocus and SetFocus why that do not work on my PC  :cry:
That was a bug that is now fixed in Alpha 8.
ASMI
« Reply #2 on: September 24, 2007, 01:16:41 PM »
Thank you. It really work in Alpha 8  :-)
