Author Topic: Drag jitters 2  (Read 14153 times)
Bryco
Drag jitters 2
« on: September 23, 2007, 07:54:18 PM »
Reading up   http://www.theswamp.org/index.php?topic=11340.msg143516#msg143516 I tried the two ways shown to drag. I want to draw a circle, that being a new entity I thought it would lend itself to EntityJig, but using both this and DrawJig give me say 10 degrees of the circle visible (1 oclock to 3 oclock) rather than the full monty. Does this happen to others?
Bryco
Re: Drag jitters 2
« Reply #1 on: September 24, 2007, 10:30:05 PM »
Same thing happens on my computor at work.
Does anyone else have a problem seeing a full circle as it is being dragged?
mohnston
  • CAD Programmer
Re: Drag jitters 2
« Reply #2 on: September 25, 2007, 11:53:10 AM »
What version of AutoCAD are you using?
CAD Programming Solutions
mohnston
  • CAD Programmer
Re: Drag jitters 2
« Reply #3 on: September 25, 2007, 12:03:20 PM »
I had to change a few lines of code but that was probably due to AutoCAD version.
Yes, I also see only part of the circle.
It is the same problem that I mentioned in my original post. The jig image never stops redrawing and therefore never gets the  chance to redraw completely.
My original problem never really got resolved.
Funny thing, I was recently working on this problem again and the jig function was working fine. No jitters. I don't remember what happened but it reverted to the same old problem.
Re: Drag jitters 2
« Reply #4 on: September 25, 2007, 12:44:48 PM »
I noticed with standard Acad commands that if you have running osnaps on then it will continue to redraw what you are dragging when the mouse moves, but if you turn them off and let it finish drawing the image of the object, it will always (almost depending on what all you have selected) be there.
Don't know if this applies to what you two are experiencing.
mohnston
  • CAD Programmer
Re: Drag jitters 2
« Reply #5 on: September 25, 2007, 01:17:57 PM »
The problem is the redraw keeps restarting even though the mouse is NOT moving.
Fatty
Re: Drag jitters 2
« Reply #6 on: September 25, 2007, 02:02:32 PM »
Just a shoot in the darkness... :|
take a look at WHIPTHREAD system variable
~'J'~
mohnston
  • CAD Programmer
Re: Drag jitters 2
« Reply #7 on: September 25, 2007, 03:32:06 PM »
~'J'~
mine is set to 1
setting it to 0 doesn't change the behavior
I did notice that using the CJIG command the full circle appears until you move your cursor. Then only part of the circle is shown.
« Last Edit: September 25, 2007, 03:34:36 PM by mohnston »
Fatty
Re: Drag jitters 2
« Reply #8 on: September 25, 2007, 04:13:58 PM »
I have a got the same result
the circle was shown partially
~'J'~
Bryco
Re: Drag jitters 2
« Reply #9 on: September 25, 2007, 06:04:01 PM »
I'm doing this in 2006 at present.
Using the ellipsejig from the arx samples.net. I see no problem, the full ellipse shows all the time.
I also can't understand why they use an aligned dimension in the sample, it's almost like they are tricking it into showing.
Perhaps the update property of a dim does the tricking?
I'll try to convert that sample to a circle tonight.
Thanks for the replies, I was starting to wonder if the answer was so simple I shouldn't have asked.
Chuck Gabriel
Re: Drag jitters 2
« Reply #10 on: September 26, 2007, 08:52:18 AM »
Maybe you've got VIEWRES set too high.
Bryco
Re: Drag jitters 2
« Reply #11 on: September 26, 2007, 10:24:11 AM »
Well viewres does indeed help, Chuck. For me a value of 10 worked for both the drawjig and entityjig method. However the circle looks like a decagon at that point, 50 started well but as the circle gets bigger it ends up about half bigger.
Here is the sample ellipse code that works.
I failed substituting the ellipse for a circle. It's a bit hard to follow as you can't really step through it.
I'ld love to know the purpose of  Dimension dim1 = new AlignedDimension();
// Copyright 2004 by Autodesk, Inc.
//Permission to use, copy, modify, and distribute this software in
//object code form for any purpose and without fee is hereby granted,
//provided that the above copyright notice appears in all copies and
//that both that copyright notice and the limited warranty and
//restricted rights notice below appear in all supporting
//documentation.
//AUTODESK PROVIDES THIS PROGRAM "AS IS" AND WITH ALL FAULTS.
//AUTODESK SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF
//MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE.  AUTODESK, INC.
//DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE
//UNINTERRUPTED OR ERROR FREE.
//Use, duplication, or disclosure by the U.S. Government is subject to
//restrictions set forth in FAR 52.227-19 (Commercial Computer
//Software - Restricted Rights) and DFAR 252.227-7013(c)(1)(ii)
//(Rights in Technical Data and Computer Software), as applicable.
using System;
using System.Reflection;
using System.IO;
using System.Collections;
using System.Diagnostics;
using Autodesk.AutoCAD.GraphicsInterface;
//[assembly: CommandClass(typeof(JigSample.TestEntityJig))]
//This application implements a command called ellipsejig. It will help you
//create an ellipse from scratch by doing a jig. The user is first asked to
//enter the ellipse major axis followed by ellipse minor axis.
//To use ellipsejig.dll:
//1. Start AutoCAD and open a new drawing.
//2. Type netload and select ellipsejig.dll.
//3. Execute the ellipsejig command, defined by ellipsejig.dll.
//Please add the References acdbmgd.dll,acmgd.dll,
//Autodesk.AutoCAD.Interop.dll and Autodesk.AutoCAD.Interop.Common.dll
//before trying to build this project.
namespace JigSample
    public class TestEntityJig
        class EllipseJig : EntityJig
            Point3d mCenterPt, mAxisPt, acquiredPoint;
            Vector3d mNormal, mMajorAxis;
            double mRadiusRatio;
            int mPromptCounter;
            DynamicDimensionDataCollection m_dims;
            public EllipseJig(Point3d center, Vector3d vec)
                : base(new Ellipse())
                mCenterPt = center;
                mNormal = vec;
                mRadiusRatio = 0.00001;
                mPromptCounter = 0;
                m_dims = new DynamicDimensionDataCollection();
                dim1.SetDatabaseDefaults();
                m_dims.Add(new DynamicDimensionData(dim1, true, true));
                Dimension dim2 = new AlignedDimension();
                dim2.SetDatabaseDefaults();
                m_dims.Add(new DynamicDimensionData(dim2, true, true));
            protected override SamplerStatus Sampler(JigPrompts prompts)
                JigPromptOptions jigOpts = new JigPromptOptions();
                jigOpts.UserInputControls = (UserInputControls.Accept3dCoordinates | UserInputControls.NoZeroResponseAccepted | UserInputControls.NoNegativeResponseAccepted);
                if (mPromptCounter == 0)
                    jigOpts.Message = "\nEllipse Major axis:";
                    PromptPointResult dres = prompts.AcquirePoint(jigOpts);
                    Point3d axisPointTemp = dres.Value;
                    if (axisPointTemp != mAxisPt)
                        mAxisPt = axisPointTemp;
                    else
                        return SamplerStatus.NoChange;
                    if (dres.Status == PromptStatus.Cancel)
                        return SamplerStatus.Cancel;
                    else
                        return SamplerStatus.OK;
                else if (mPromptCounter == 1)
                    jigOpts.BasePoint = mCenterPt;
                    jigOpts.UseBasePoint = true;
                    jigOpts.Message = "\nEllipse Minor axis:";
                    double radiusRatioTemp = -1;
                    PromptPointResult res = prompts.AcquirePoint(jigOpts);
                    acquiredPoint = res.Value;
                    radiusRatioTemp = mCenterPt.DistanceTo(acquiredPoint);
                    if (radiusRatioTemp != mRadiusRatio)
                        mRadiusRatio = radiusRatioTemp;
                    else
                    if (res.Status == PromptStatus.Cancel)
                    else
                else
            protected override bool Update()
                double radiusRatio = 1.0;
                switch (mPromptCounter)
                    case 0:
                        // At this time, mAxis contains the value of one
                        // endpoint of the desired major axis.  The
                        // AcDbEllipse class stores the major axis as the
                        // vector from the center point to where the axis
                        // intersects the ellipse path (such as half of the true
                        // major axis), so we already have what we need.
                        mMajorAxis = mAxisPt - mCenterPt;
                        break;
                    case 1:
                        // Calculate the radius ratio.  mRadiusRatio
                        // currently contains the distance from the ellipse
                        // center to the current pointer position.  This is
                        // half of the actual minor axis length.  Since
                        // AcDbEllipse stores the major axis vector as the
                        // vector from the center point to the ellipse curve
                        // (half the major axis), to get the radius ratio we
                        // simply divide the value currently in mRadiusRatio
                        // by the length of the stored major axis vector.
                        radiusRatio = mRadiusRatio / mMajorAxis.Length;
                        break;
                try
                    ((Ellipse)Entity).Set(mCenterPt, new Vector3d(0, 0, 1), mMajorAxis, radiusRatio, 0.0, 6.28318530717958647692);
                    UpdateDimensions();
                catch (System.Exception)
                    return false;
                return true;
            protected override DynamicDimensionDataCollection GetDynamicDimensionData(double dimScale)
                return m_dims;
            protected override void OnDimensionValueChanged(Autodesk.AutoCAD.DatabaseServices.DynamicDimensionChangedEventArgs e)
            void UpdateDimensions()
                    Ellipse myellipse = (Ellipse)Entity;
                    AlignedDimension dim = (AlignedDimension)m_dims[0].Dimension;
                    dim.XLine1Point = myellipse.Center;
                    dim.XLine2Point = mAxisPt;
                    dim.DimLinePoint = myellipse.Center;
                else
                    AlignedDimension dim2 = (AlignedDimension)m_dims[1].Dimension;
                    dim2.XLine1Point = myellipse.Center;
                    dim2.XLine2Point = acquiredPoint;
                    dim2.DimLinePoint = myellipse.Center;
            public void setPromptCounter(int i)
                mPromptCounter = i;
            public Entity GetEntity()
                return Entity;
        [CommandMethod("ellipsejig")]
        static public void DoIt()
            PromptPointOptions opts = new PromptPointOptions("\nEnter Ellipse Center Point:");
            PromptPointResult res = ed.GetPoint(opts);
            Vector3d x = Application.DocumentManager.MdiActiveDocument.Database.Ucsxdir;
            Vector3d y = Application.DocumentManager.MdiActiveDocument.Database.Ucsydir;
            Vector3d NormalVec = x.CrossProduct(y);
            Database db = Application.DocumentManager.MdiActiveDocument.Database;
            Autodesk.AutoCAD.DatabaseServices.TransactionManager tm = db.TransactionManager;
            //Create Ellipsejig
            EllipseJig jig = new EllipseJig(res.Value, NormalVec.GetNormal());
            //first call drag to get the major axis
            jig.setPromptCounter(0);
            Application.DocumentManager.MdiActiveDocument.Editor.Drag(jig);
            // Again call drag to get minor axis
            jig.setPromptCounter(1);
            //Append entity.
            using (Transaction myT = tm.StartTransaction())
                BlockTable bt = (BlockTable)tm.GetObject(db.BlockTableId, OpenMode.ForRead, false);
                BlockTableRecord btr = (BlockTableRecord)tm.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite, false);
                btr.AppendEntity(jig.GetEntity());
                tm.AddNewlyCreatedDBObject(jig.GetEntity(), true);
                myT.Commit();
mohnston
  • CAD Programmer
Re: Drag jitters 2
« Reply #12 on: September 26, 2007, 12:53:29 PM »
Viewres did not help.
The objects I'm dragging have no arcs.
In the code that does the inserting I noticed a line that checks to see if the cursor has moved.
if (position.DistanceTo(curPoint) > 1.0e-4)When dragging I can take my hand completely off the mouse and the image continues to flicker as if the sampler fires regardless of cursor movement.
In normal AutoCAD operation when a entities are dragged and you stop your cursor movement the image eventually catches up and is stable until the cursor moves again.
« Last Edit: September 26, 2007, 12:54:43 PM by mohnston »
Bryco
Re: Drag jitters 2
« Reply #13 on: September 26, 2007, 05:52:31 PM »
Mark that's another thing I can't get the grip of.
{mAxisPt = axisPointTemp;}
this sequence from the ellipsejig compares mousepoints and if not the same changes the field (vba module level variable), if there is no change
I guess the update function must take care of it.
Re: Drag jitters 2
« Reply #14 on: September 26, 2007, 06:10:40 PM »
From a graphical point of view, the application needs to tell the object to update and draw itself based on the current position as the mouse moves (the OnMouseMove() event say), when the mouse is not moving the app shouldn't call update/draw.
I'd imagine this all happens while the jig has a certain status set. If it is still sending messages to update/draw when the mouse isn't moving it will cause flickering or missing pixels as the frame buffer is continually swapping/updating itself which an 'interactive' application like acad doesn't handle so well.
I'd be looking for some flag or similar that controls the update of the image and make sure it's being used correctly.
Not much help but something to think about perhaps.
- John Carmack
- J.R.R. Tolkien
