Thanks guys,
diarmuid, I'll look that up for sure....sounds good to me.
Keith, for ddedit and ddatte, I changed my pgp file to call a lisp routine I use in place of these commands...it will load the appropriate editor depending on what type of entity is selected. Sometimes the old rev blocks here are straight text and sometimes, they're attributes...
Of course, since, 2002, the ol' double click helps too, but I like my MET lisp.
;MET: MET.LSP Edit Text (c)2000, Jay Thomas
;Modified by Mike Williams - May, 2003
(defun C:MET (/ SS CNT NUM ENT ANS oldsnp)
(command"undo""group")
(prompt "\n Multi Edit Text, Attributes, or Dimensions. ")
(if(>=(getvar"acadver")"13")
(setq SS (ssget '((-4 . "<or")(0 . "ATTDEF")(0 . "DIMENSION")
(0 . "MTEXT")(0 . "TEXT")(0 . "TOLERANCE")
(-4 . "<and")(0 . "INSERT")(66 . 1)(-4 . "and>")(-4 . "or>"))))
(setq SS (ssget '((-4 . "<or")(0 . "ATTDEF")(0 . "TEXT")
(-4 . "<and")(0 . "INSERT")(66 . 1)(-4 . "and>")(-4 . "or>")))))
(if SS
(setq NUM (sslength SS) CNT 0)
(while(< CNT NUM)
(princ(strcat"\r Edit Text or Attribute: "(rtos(1+ CNT) 2 0)" of "(rtos NUM 2 0)": "))
(setq ENT (ssname SS CNT))
(setq ANS (cdr(assoc 0(entget ENT))))
((or(eq ANS "ATTDEF")(eq ANS "DIMENSION")(eq ANS "MTEXT")
(eq ANS "TEXT")(eq ANS "TOLERANCE"))
(command "DDedit" ENT \))
((eq ANS "INSERT")
(command "DDatte" ENT \))
(entupd ENT)
(setq CNT (1+ CNT))
(princ" Done... "))
(princ" Nothing selected. "))
(command"undo""end")
) ;EOF
