Hi Alls,
This code is for display arrow rotating when you load a program.
load 2 codes and type asar.
; sar is stand for Symbol Arrow Rotation
; Design by : Adesu <Ade Suharna>
; Email : mteybid@yuasabattery.co.id
; Homepage : http://www.yuasa-battery.co.id
; Website : http://cadesu.multiply.com
; Create : 14 September 2007
; Program no.: 0654/09/2007
; Edit by : Adesu 19/09/2007 1).
(defun dtr (a)
(* pi (/ a 180.0))
(defun c:sar (/ ang1 ang2 el1 el2 el4 el5 el6 el7 p1 p10 p11
p12 p2 p3 p4 p5 p6 p7 p8 p9 pt rad1 rad2 ss)
(setq pt '(0 0 0))
(setq rad1 4)
(command "_circle" pt rad1 "")
(setq el1 (entlast))
(setq rad2 6)
(command "_circle" pt rad2 "")
(setq el2 (entlast))
(setq ang1 160)
(setq p1 (polar pt (dtr ang1) 3))
(setq p2 (polar pt (dtr ang1) 7))
(command "_line" p1 p2 "")
(setq el4 (entlast))
(setq p3 (polar pt 0 4))
(setq p4 (polar pt 0 6))
(command "_line" p3 p4 "")
(setq el5 (entlast))
(setq p5 (polar pt pi rad1))
(setq p6 (polar pt pi rad2))
(command "_trim" el4 el5 "" p5 p6 "")
(setq ang2 350)
(setq p7 (polar pt (dtr ang2) 4))
(setq p8 (polar pt (dtr ang2) 6))
(command "_trim" el5 "" p7 p8 "")
(setq p9 (polar pt (dtr ang1) 5))
(command "_trim" el1 el2 "" p9 "")
(setq p10 (polar pt pi 5))
(command "_line" p1 p10 p2 "")
(setq ss (ssget "x" '((0 . "ARC,LINE"))))
(command "_pedit" "l" "j" ss "" "")
(setq el6 (entlast))
(command "_mirror" el6 "" p4 p6 "")
(setq el7 (entlast))
(setq p11 (polar pt (* pi 0.5) rad1))
(setq p12 (polar pt (* pi 1.5) rad1))
(command "_mirror" el7 "" p11 p12 "y" "")
(command "_zoom" "e") ; 1).
) ; defun
; asar is stand for Animation Symbol Arrow Rotation
; Create : 19 September 2007
; Program no.: 0655/09/2007
; Edit by : Adesu 20/09/2007 1). all format
(defun dtr (a)
(* pi (/ a 180.0))
(defun *line* (lst)
(foreach x lst
(setq pt1 (polar pt (dtr x) 4))
(setq pt2 (polar pt (dtr x) 6))
(command "_line" pt1 pt2 "")
) ; foreach
) ; defun
(defun *hatch* (lst)
(foreach x lst
(setq pt3 (polar pt (dtr x) 5))
(command "_bhatch" "p" "ansi31" 0.25 0 pt3 "")
(setq el (entlast))
(setq lsth (append lsth (list el)))
) ; foreach
) ; defun
(defun *erase* (lsth)
(foreach x lsth
(command "_erase" x "")
) ; foreach
) ; defun
(defun c:asar (/ pt pt1 pt2 el lsth pt3 lst1 lst2
lst3 lst4 lsth pt rad1 rad2)
(c:sar)
(setq pt '(0 0 0))
(setq rad1 4)
(setq rad2 6)
(setq lst1 '(0 20 40 60 80 100 120 140 160))
(*line* lst1)
(setq lst2 '(180 200 220 240 260 280 300 320 340))
(*line* lst2)
(setq lst3 '(10 30 50 70 90 110 130 150 170))
(setq lst4 '(190 210 230 250 270 290 310 330 350))
(repeat
10
(*hatch* lst3)
(*erase* lsth)
(*hatch* lst4)
(*erase* lsth)
) ; repeat
) ; defun
