OK guys and gals... I've been working on a program called dimbal.lsp and I have the authors permission to modify it as much as I like.
It's in the LilyPond under PDJ and basically I have the main .lsp there with the accompanying .dcl as well as all the .sld files that go with it.. Then you'll see my version of it called newtag.lsp and also a hook.sld file. The problem I'm having is that when I run the hook part, I get an extra line in the leader part. One line extends into the hexagon, the other line extends into the hook so, either way, if I delete one, I still have to trim the other..
Basically, just put all the files into a directory and load dimbal and run it, you'll see how it's supposed to work.. Then run newtag and you'll see the hook.sld in the routine now.. That's where the error happens.
Any help is greatly appreciated.. I use this routine for labeling ground wires on antennas and I've got about 40 antennas to do in the next few weeks..
