Author Topic: How to Sort a ComboBox?  (Read 3631 times)
Humbertogo
« on: September 05, 2007, 07:50:30 AM »
Is there a way to sort comboboxes alphabetically
hendie
Re: How to Sort a ComboBox?
« Reply #1 on: September 05, 2007, 08:02:20 AM »
author unknown
Public Function CBsort(CB As ComboBox)
' Sort the Combobox
    Dim CBvar As Variant
    For I = 0 To CB.ListCount - 2
        If CB.List(I) > CB.List(I + 1) Then
            CBvar = CB.List(I)
            CB.List(I) = CB.List(I + 1)
            CB.List(I + 1) = CBvar
            I = -1
        End If
    Next I
End Function
Humbertogo
« Reply #2 on: September 05, 2007, 08:19:50 AM »
Thanks for the code.
only this take a long time to sort a list with in 90.00000 items :-(
Guest
« Reply #3 on: September 05, 2007, 08:24:29 AM »
Sort the information PRIOR to adding it to the combobox.  What's your code look like?  Can you post a snippet?
hendie
« Reply #4 on: September 05, 2007, 08:32:03 AM »
it might be easier/faster to read the items into an array, sort the array then add the array to the combobox
« Reply #5 on: September 05, 2007, 09:22:35 AM »
How many ??
Bryco
« Reply #6 on: September 05, 2007, 09:40:32 AM »
http://vbnet.mvps.org/index.html?code/sort/qsoverview.htm
QuickSort may be the one, but it will take a few seconds for sure
hendie
« Reply #7 on: September 05, 2007, 10:06:48 AM »
How many ??
exactly !
why would you want/need to add 9000000 items to a combo box ??????
« Reply #8 on: September 05, 2007, 01:25:51 PM »
The simple solution is to set the Sorted property to True in the IDE at designtime.
At runtime a ComboBox Sorted property is read only, thus you need to set it prior to running the code.
Guest
« Reply #9 on: September 05, 2007, 01:30:31 PM »
But a ComboBox in VBA doesn't have an option for SORTED. (unless it's called something else??)
« Reply #10 on: September 05, 2007, 01:42:30 PM »
Hmmmm .. I have been working in VB recently .. hadn't considered the fact the properties would be different in VB and VBA ...
let me see what I can come up with
Humbertogo
« Reply #11 on: September 10, 2007, 09:59:09 AM »
thanks
  'fill MyArray
  For i = 1 To UBound(ComboBox1.List)
    MyArray(i) = ComboBox1.List(i)
  Next i
QuickSort MyArray, LBound(MyArray), UBound(MyArray)
  ComboBox1.Clear
   'use sorted array to refill ComboBox
  For i = 1 To UBound(MyArray)
  If MyArray(i) <> "" Then _
    ComboBox1.AddItem MyArray(i)
  Next i
Private Sub QuickSort(strArray() As String, intBottom As Integer, intTop As Integer)
  Dim strPivot As String, strTemp As String
  Dim intBottomTemp As Integer, intTopTemp As Integer
  intBottomTemp = intBottom
  intTopTemp = intTop
  strPivot = strArray((intBottom + intTop) \ 2)
  While (intBottomTemp <= intTopTemp)
    While (strArray(intBottomTemp) < strPivot And intBottomTemp < intTop)
      intBottomTemp = intBottomTemp + 1
    Wend
    While (strPivot < strArray(intTopTemp) And intTopTemp > intBottom)
      intTopTemp = intTopTemp - 1
    Wend
    If intBottomTemp < intTopTemp Then
      strTemp = strArray(intBottomTemp)
      strArray(intBottomTemp) = strArray(intTopTemp)
      strArray(intTopTemp) = strTemp
    End If
    If intBottomTemp <= intTopTemp Then
    End If
  Wend
  'the function calls itself until everything is in good order
  If (intBottom < intTopTemp) Then QuickSort strArray, intBottom, intTopTemp
  If (intBottomTemp < intTop) Then QuickSort strArray, intBottomTemp, intTop
hendie
« Reply #12 on: September 10, 2007, 10:03:03 AM »
It appears you are reading the list into the combobox, then reading the combobox list into an array.
Why not make it quicker by not reading into the combobox to begin with.. just read the items directly into the array
Guest
« Reply #13 on: September 10, 2007, 10:04:13 AM »
Here's one that I've used quite a bit...
Sub BubbleSort(arr As Variant, Optional descending As Boolean, Optional numEls As Variant)
' Bubble Sort an array of any type
' Author: The VB2TheMax Team
' BubbleSort is especially convenient with small arrays (1,000
' items or fewer) or with arrays that are already almost sorted
' NUMELS is the index of the last item to be sorted, and is
' useful if the array is only partially filled.
' Works with any kind of array, except UDTs and fixed-length
' strings, and including objects if your are sorting on their
' default property. String are sorted in case-sensitive mode.
' You can write faster procedures if you modify the first two lines
' to account for a specific data type, eg.
' Sub BubbleSortS(arr() As Single, Optional descending As Boolean, Optional numEls As Variant)
'   Dim value As Single
    Dim Value As Variant
    Dim Index As Long
    Dim firstItem As Long
    Dim indexLimit As Long, lastSwap As Long
    ' account for optional arguments
    If IsMissing(numEls) Then numEls = UBound(arr)
    firstItem = LBound(arr)
    lastSwap = numEls
    Do
        indexLimit = lastSwap - 1
        lastSwap = 0
        For Index = firstItem To indexLimit
            Value = arr(Index)
            If (Value > arr(Index + 1)) Xor descending Then
                ' if the items are not in order, swap them
                arr(Index) = arr(Index + 1)
                arr(Index + 1) = Value
                lastSwap = Index
            End If
        Next
    Loop While lastSwap
