Author Topic: Save Multi-Column Listbox to Text File  (Read 1910 times)
Guest
« on: September 04, 2007, 09:18:00 AM »
I've got a multicolumn listbox that has block names and counts.  I want to save the info to a TXT file but maintain the columns.  I know how to save to a TXT file, but I don't know how to maintain those columns.  Tabs won't work because some block names are longer than others and by using a tab for spacing, it may end up kicking a block count out of alignment.
Ideally what I'd like to do is have a set string length for the block names (it would need to include spaces to make up the difference of the other shorter/longer block names) and then have a set length for the block count.
I hope this is making sense.
Right now, if I save the block count info to a TXT file, it would look something like this...
EXISTING DATA/VOICE OUTLET  2
EXISTING VOICE OUTLET   4
NEW AUDIO/VIDEO OUTLET  2
NEW DATA OUTLET 2
NEW DATA/VOICE OUTLET   3
NEW VOICE OUTLET    2
But I want it to look like this....
EXISTING DATA/VOICE OUTLET2
EXISTING VOICE OUTLET4
NEW AUDIO/VIDEO OUTLET2
NEW DATA OUTLET2
NEW DATA/VOICE OUTLET3
NEW VOICE OUTLET2
Re: Save Multi-Column Listbox to Text File
« Reply #1 on: September 04, 2007, 09:39:35 AM »
Unless you are using a fixed width font the text won't exactly line up anyway, but you can get it close ....
Try this to expand the length of the description to a desired length:
Public Function ExpandText (ByVal strSource As String, ByVal intLength As Integer) As String
While Len(strSource) < intLength
 strSource = strSource & " "
Wend
ExpandText = strSource
End Function
Then append the count to the end
Guest
« Reply #2 on: September 04, 2007, 09:46:39 AM »
That's perfect!  Thanks, Keith.
« Reply #3 on: September 04, 2007, 09:56:18 AM »
You are welcome ...
Guest
« Reply #4 on: September 04, 2007, 02:33:26 PM »
So I made a slight change to the function below - substituted the space with a period and now my output looks like below.
      strSource = strSource & "."
   Wend
End Function
TXT file output.
Device Name                   #
EXISTING DATA OUTLET...................................3
EXISTING DATA/VOICE OUTLET.........................3
EXISTING VOICE OUTLET.................................3
EXISTING WAP...............................................1
NEW DATA OUTLET.........................................6
NEW WAP......................................................2
NEW WAP (WALL-MOUNTED).............................4
Thanks again, Keith!
« Reply #5 on: September 04, 2007, 03:02:45 PM »
Glad it worked for you .. now if I could get someone to help me figure out how to dynamically create a bitmap in memory that can be put into a ImageList, I would be all set
