Not that I know of, but try the quick revised code
;;;===================[ ArcByLength-Ver2A.lsp ]=========================
;;; Author: Charles Alan Butler
;;; Version: 2A Sep 4 2007
;; Note: This is a vairation of the original routine
;;; Purpose: To draw an arc from chord & arc length
;;; Restrictions:
;;; Arc length must greater than the chord length
(defun c:arcbyl (/ arc_angle arc_length chord_length end_point arc_radius
start_point usercmd useros
(setq usercmd (getvar "CMDECHO"))
(setvar "CMDECHO" 0)
(setq useros (getvar "osmode"))
;; x-x-x-x-x-x-x-x-x-x-x-x
;; returns the factor
(defun factor (arc_length chord_length / k n c e)
(setq k (/ chord_length arc_length))
(setq n 0)
(repeat 6
(if (= n 0)
(setq c (sqrt (- 6 (* 6 k))))
(setq c (- c (/ (- (sin c) (* k c)) (- e k))))
(setq e (cos c))
(setq n (1+ n))
c
;; S t a r t o f R o u t i n e
(if (and
;;(setq start_point (getpoint "\nPick start point. "))
;;(setq end_point (getpoint "\nPick end point."))
(setq chord_length (getdist "\nEnter chord length. "))
(setq arc_length (getdist "\nEnter arc length. "))
(and chord_length ; (setq chord_length (distance start_point end_point))
(or (< arc_length (* chord_length 6))
(not (prompt "\n** Warning, Large arc length used. **"))))
(or (> arc_length chord_length)
(prompt "\n*** Arc length too short. **"))
(if (setq arc_angle (* 2 (factor arc_length chord_length)))
;; Ver 2A
(setq end_point '(0 0))
(setq start_point (polar end_point 0.0 chord_length))
(setq arc_radius (/ arc_length arc_angle))
;;(setvar "osmode" 0)
;;(command "_.arc" start_point "EN" end_point "A" (* 180.0 (/ arc_angle pi)))
(command "_.arc" "_non" start_point "EN" "_non" end_point "A" (* 180.0 (/ arc_angle pi)))
(command "_.move" (entlast) "" "_non" end_point pause)
(setvar "osmode" useros)
(prompt "\n*** Error in user input. Command terminated. ***")
(prompt "\nArc By Length loaded, Enter ArcByL to run.")
