Author Topic: *ANSWERED* Is a save required  (Read 2980 times)
Ron Heigh
« on: July 16, 2004, 12:45:43 PM »
Is there a variable I can check to see if a drawing needs to be saved before closing it?
Ron Heigh
« Reply #1 on: July 16, 2004, 01:26:59 PM »
Found It
DBMOD System Variable Concepts Procedures Reference
(Read-only)
Type: Integer
Not saved
Indicates the drawing modification status using bitcode. The value is the sum of the following:
1  Object database modified
4  Database variable modified
8  Window modified
16  View modified
AutoCAD resets the DBMOD value to 0 when you save the drawing.
t-bear
« Reply #2 on: July 16, 2004, 01:28:59 PM »
Hey there,Ron...try this:
(Read-only)
Type: Integer
Not saved
8  Window modified
16  View modified
« Reply #3 on: July 16, 2004, 01:30:58 PM »
Ron, i would try the "DBMOD" variable.
Ron Heigh
« Reply #4 on: July 16, 2004, 01:31:15 PM »
Thanks T-Bear
t-bear
« Reply #5 on: July 16, 2004, 01:44:08 PM »
:lol:  :lol:  :lol:  :lol:  :lol:  :lol:  :lol:  :lol:  :lol:  :lol:  :lol:  :lol:
