Author Topic: Total distance (ARC,LINE,LWPOLYLINE,POLYLINE) by layer  (Read 2506 times)
jav
  • Mosquito
« on: August 30, 2007, 06:10:38 PM »
Is there a routine out there anywhere that will list the total length of a group of lines that are on the same layer?
For example if we layout a bunch of pipe 3/4" dia. on one layer and more pipe, say 1 1/4", on another layer, it would be great if you could get the total length of pipe for each layer.
Thanks for any help.
Re: Total distance (ARC,LINE,LWPOLYLINE,POLYLINE) by layer
« Reply #1 on: August 30, 2007, 07:35:16 PM »
Give this a try:
(defun c:totalen (/ total lay ss lst output)
  (setq total 0
lay   (cdr
(assoc
  8
  (entget
    (car (entsel "\n Select object to set layer filter: "))
ss    (ssget (list (cons '0 "LINE,*POLYLINE,SPLINE,ARC,CIRCLE")
   (cons '8 lay)
  (if (and lay ss)
      (setq
lst (mapcar 'vlax-ename->vla-object
    (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
      (mapcar '(lambda (x)
(setq len   (vlax-curve-getdistatparam
       x
       (vlax-curve-getendparam x)
       total (+ total len)
      lst
      (setq output
     (strcat "\n"
     (itoa (sslength ss))
     " objects on layer ''"
     lay
     "'' have a total length of  -  "
     (rtos total (getvar 'lunits) 3)
      (alert output)
      (princ output)
jav
  • Mosquito
« Reply #2 on: August 31, 2007, 05:25:13 PM »
Thanks very much ronjonp
« Reply #3 on: August 31, 2007, 10:55:48 PM »
You're welcome  :-)
VVA
« Reply #4 on: September 04, 2007, 01:50:59 AM »
Count on all layers taking into account correction factor
(defun c:mlen (/ m ss clist temp)
  (defun sort (lst predicate)
    (mapcar '(lambda (x) (nth x lst)) (vl-sort-i lst predicate))
  (defun combine (inlist is-greater is-equal / sorted current result)
    (setq sorted (sort inlist is-greater))
    (setq current (list (car sorted)))
    (foreach item (cdr sorted)
      (if (apply is-equal (list item (car current)))
  (setq current (cons item current))
    (setq result (cons current result))
    (setq current (list item))
  (defun mlen3_1 (lst / sum_len)
    (setq sum_len 0)
    (foreach item (mapcar 'car lst)
      (setq
  sum_len  (+ sum_len
       (if (vlax-property-available-p item 'length)
         (vla-get-length item)
        (strcase (vla-get-objectname item) t)
        "acdbarc"
      ) ;_  =
      (vla-get-arclength item)
        "acbcircle"
      ) ;_  =
      (* pi 2.0 (vla-get-radius item))
           (t 0.0)
         ) ;_  cond
       ) ;_  if
    ) ;_  +
    (if  (not (zerop sum_len))
      (princ
  (strcat "\n\t" (cdar lst) " = " (rtos (* sum_len m) 2 4))
  (and
    (if (null (setq m (getreal "\nEnter correction factor <1>:\t")))
      (setq m 1) t)
    (setq ss (ssget "_:L"))
    (setq ss (mapcar
         (function vlax-ename->vla-object)
         (vl-remove-if
     (function listp)
     (mapcar
       (function cadr)
       (ssnamex ss)
     ) ;_  mapcar
         ) ;_ vl-remove-if
         (setq temp (cons (cons x (vla-get-Layer x)) temp))
      ss
    (setq clist  (combine temp
       '(lambda (a b)
          (> (cdr a) (cdr b))
       '(lambda (a b)
          (eq (cdr a) (cdr b))
    (princ
      "\n\nTotal length by layer:"
    (mapcar 'mlen3_1 clist)
) ;_  defun
