Author Topic: Exploding on insert of a block in vba  (Read 2257 times)
krampaul82
« on: August 28, 2007, 12:57:26 PM »
To Whom it may concern, I am a VBA Newby, Please be kind....
I am loading an ACAD block through a VBA program(see attached) into a drawing. I then want to explode that loaded block.  I found some script code in vba called send to command line (see attached) but it does not work It sends what looks like bar code to the command line.  Maby I'm making this way to complicated and should just let the user explode the block? Any advise would greatly be appreciated.  Many thanks to cmdrduh for your previous help on combobox!! you advise worked fine.:x
David Hall
  • Automatic Duh Generator
Re: Exploding on insert of a block in vba
« Reply #1 on: August 28, 2007, 03:17:38 PM »
From your code
Dim blockRefObj As AcadBlockReference
    Set blockRefObj = ThisDrawing.ModelSpace.InsertBlock(returnPnt, "C:\Acad_2008\2008_Blocks\Controllers\nxs0015a1007-01.dwg", 1#, 1#, 1#, 0)
blockRefObj.explode
krampaul82
« Reply #2 on: August 28, 2007, 03:32:12 PM »
From your code
blockRefObj.explode
I wasn't even close thank you for putting up with me......
David Hall
« Reply #3 on: August 28, 2007, 05:23:25 PM »
So did it work?
